Honeycomb replacement
Old May 25, 2004 | 10:44 PM
CDN_Rhino's Avatar
CDN_Rhino
Default RE: Honeycomb replacement
How about this.......... http://www.mustangtuning.com/ho.html ........ is this what you are looking at I am.
Old May 25, 2004 | 11:27 PM
dubie76's Avatar
dubie76
I don't have a problem with the water puddling under the scoop. Just in those stupid honeycomb holes.
CDN_Rhino, that looks kool, but that will definately not stop water from pooling in the scoop. I am looking for a solid flat piece of something. Maybe I could get a polished piece of stainless cut to fit, and glue it somehow. What do you all think?
Old May 26, 2004 | 08:03 PM
CDN_Rhino's Avatar
CDN_Rhino
Do you or a friend have access to a milling machine. You can take a solid piece of stainless steel or aluminium with a pattern of shallow blind holes. Paint it black and then clean the paint off the face so it will give the impression that air can flow threw it. Then put a rubber seal around it.
OR park so your rear end is higher than your front end.
I just [:@]curse [:@]alot and clean up the water as it runs out of the scoop like snot out of a kid's nose!!!!!
Old May 31, 2004 | 11:00 PM
CDN_Rhino's Avatar
CDN_Rhino
Today I took out my honey comb insert, and tomorrow I am going to start making my own out of S.S. mesh....same as the link I posted. It should be no prob. I have all the tools at work and I have the mesh. Hope it goes smooth. Next I'm going to exchange those ugly side scoops for GT ones.
Old Jun 1, 2004 | 03:42 AM
dubie76's Avatar
dubie76
Let me know it turn out! I am interested in seeing what you come up with.
Old Jun 2, 2004 | 03:00 PM
CDN_Rhino's Avatar
CDN_Rhino
I just finished it an hour ago, I'm at work right now but I'll post some pics in about 3 hours...... 4:00 Detroit time. It was hard tig welding the bolt ends on to the mesh but it is done except maybe alittle grinding to fit it in.
Old Jun 2, 2004 | 06:42 PM
CDN_Rhino's Avatar
CDN_Rhino
Here's some pic's, it's raining now so I will put it on later today and post a pic.... I've never posted pic's before so I hope they turn out and are not to large!
[IMG]local://upfiles/6856/Qo402499372.jpg[/IMG]
[IMG]local://upfiles/6856/Pk319168555.jpg[/IMG]
[IMG]local://upfiles/6856/Sx611391848.jpg[/IMG]
Old Jun 2, 2004 | 08:04 PM
CDN_Rhino's Avatar
CDN_Rhino
The pic's above was version 1.0 this is version 1.5.
I didn't have the scoop with me at work I just went with a rough template and a bad memory, I changed it to version 1.5 at home it works but I'm going to make one more, (I'm taking the scoop to work this time).
This is version 1.5.........
[IMG]local://upfiles/6856/Ig109878522.jpg[/IMG]
[IMG]local://upfiles/6856/Tr508750898.jpg[/IMG]
Old Jun 4, 2004 | 08:04 PM
CDN_Rhino's Avatar
CDN_Rhino
Here are the pictures of Version 2.0 it fits better, if any one wants better pictures you can e-mail me. These are resized and don't show much detail. Now I need to get the Mach 1 Grill insert......
[IMG]local://upfiles/6856/Us535585004.jpg[/IMG]
[IMG]local://upfiles/6856/To452254188.jpg[/IMG]
[IMG]local://upfiles/6856/Pu517499942.jpg[/IMG]
[IMG]local://upfiles/6856/Ic841564060.jpg[/IMG]
Old Jun 5, 2004 | 12:10 AM
dubie76's Avatar
dubie76
Looks great! Won't you have the same problem with water getting in the scoop as you did with the honeycomb? With that screen, it will pass all the way into the scoop!
Anyway, are you selling them? Are you going to make matching ones for the side scoops?
