Proper touch up techniques
Old Jul 28, 2006 | 10:42 AM
Big Red's Avatar
Big Red
Default Proper touch up techniques
Hey guys, I have a rock chip on the side of my stang I want to fix, a body shop I had my car at did a quick job on it while they were working on something else and just covered it up, but it really has no gloss or anything. I want to try and make this chip as unnoticeable as possible so whats the best method to do? I have Motorcraft touch up from the dealer, should I just hit it with that on top of the touch up already on there?
then should I wet sand it with like, 1200 grit? Or just compound it? Thanks in advance.
Old Jul 28, 2006 | 10:43 AM
Big Red's Avatar
Big Red
Default RE: Proper touch up techniques
btw its a big *** chip otherwise I wouldnt bother
Old Jul 29, 2006 | 11:33 AM
tim1200's Avatar
tim1200
I bought some touch up paint and was interested in seeing what the answer is too. Anyone know how well the pen works?
Old Jul 29, 2006 | 12:10 PM
TwotoneVert's Avatar
TwotoneVert
Where on the door is the chip located and how old is the paint, do you have a lot of fade?
Old Jul 29, 2006 | 05:47 PM
tim1200's Avatar
tim1200
My paint is almost new, no fading, the OP had the chip on the door.
Old Jul 30, 2006 | 12:29 AM
TwotoneVert
If it is a really big chip, and and you have to use paint. I would recommend you sand the area with a P500 grit paper, its available at most automotive paint shops, and it is NOT the same a usual 500 grit paper, or you can use a grey scotch bright pad. Wet sand the area you want to touch up, and use the paint code on your door jam to purchase a pint of paint. I would not bother to primer, you are only touching up what is there. Use a touch up gun and paint the area you are fixing, then clear coat the entire area. If you are painting above the trim, only clear coat above the trim. Do NOT paint the entire door, you will not get lucky enough to match the paint perfectly and you will see a difference if you paint edge to edge. If you just touch up, and clear coat the whole door, or above the trim, you will be able to feather out the paint so as not to see the difference. Remember to roll the edges of the tape up, around where you mask off so that you will be able to wet sand them down without much trouble. I know this is involved, but I am sometimes **** about my car, I want it to be right, and sometimes you have to fool the eye. Good luck. BTW, I hate the way the dob on touch up paint looks.
Old Jul 30, 2006 | 03:43 AM
Big Red's Avatar
Big Red
Its not on my door, its on the quarter panel just behind the door. thanks for the tips, I figured I would have to wet sand with a high grit.
Old Jul 30, 2006 | 01:09 PM
TwotoneVert
Just dont paint to the edge of the door and panel, you will see a color diff.
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
Sep 30, 2015 12:39 PM
Sep 25, 2015 06:42 PM
yourmom6990
Sep 14, 2015 10:52 PM
