Tint scratches
Old Aug 21, 2006 | 10:29 PM
05gtdriver's Avatar
05gtdriver
Default Tint scratches
Hello all, has any '05 & up owners had problems with the front side windows getting vertical scratches after getting the windows tinted?
My front side windows look like a football field! Any suggestions/tips? Thanks
Old Aug 21, 2006 | 10:53 PM
02 Stang's Avatar
02 Stang
Default RE: Tint scratches
You aren't supposed to roll your windows up or down in the first week or so after the tinting.
Old Aug 22, 2006 | 12:37 AM
05gtdriver's Avatar
05gtdriver
I didn't roll them down/up for 4 days(per installer instructions). They told me(after revealing the scratches) that the '05s have a hard plastic strip to keep the window from rattling, this is what's causing the scratches, according to them. Any thoughts from '05 & up owners with tinted windows? Any solutions?
Old Aug 23, 2006 | 02:04 AM
Dan04COBRA's Avatar
Dan04COBRA
You can roll the windows down after 12+ hours if the temps don't get too cold.
Those ridiculous wait times the shops give you is just to cover their hide incase you leave the lot and roll down the window & snag an egde. If they tint the windows properly and don't leave globs of solution under the tint, it won't slide & if they heat shrink the edges like they should, they won't snag.
Anyways, check out our 2005+ Mustang section, there is a whole bunch of threads about the window scratching. Hopefully you can find the help you need in there.
Old Aug 26, 2006 | 01:23 AM
BigNasty06's Avatar
BigNasty06
ORIGINAL: 05gtdriver
Yep, very common. Call Ford and they act like they never heaqrd of it. I had my felt replaced by a shop that was familiar with the Mustang problem. Had the windows redone and didn't lower the windoes for 5 days. The passesnger side already has scratches again in the exact same spots.
This is not a felt issue... The scratches are in the exact same spot for everyone, towards the front of the windows by the inside door handle. Has to be a design flaw with the windows and/or handles.
Check out the 2005/2006/2007 Forum. There is a sticky note on this issue. Call FOMOCO and complain! Make sure you have your VIN.
Old Aug 26, 2006 | 01:49 PM
crmstang's Avatar
crmstang
i have a 98 and it has the same thing. so then is it like that for all mustangs? because i thought i had something in my door that was scratching my tint off. is there anything to try to fix it or do i just leave as is?
Old Aug 26, 2006 | 11:01 PM
BigNasty06's Avatar
BigNasty06
Some people have replace the factory felt with a moleskin kit, and that supposedly works.
I had my felt replaced, retinted, and had a scratch on the passenger's windows after lowering the window MAYBE 5 times.
I'm done dealing with it... I'll just keep my fingers crossed that I don't get too many more scratches.
JonnyBlazeGT
Nov 3, 2015 01:10 AM
chrisdbassplayer
Oct 13, 2015 06:53 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
mustangchef
Sep 4, 2015 08:08 PM
James Watson
Aug 6, 2015 06:42 AM
