Vertical doors?
Old Jul 5, 2004 | 03:47 PM
  #21
Rons2001GT's Avatar
Rons2001GT
Default RE: Vertical doors?
how exactly do those doors open though? I mean the sites I saw use the old door latches, so do you first have to open the door a bit and then slide it up? Or is there another way? Just wondering before I get too attached to the idea of lambo doors.
Old Jul 5, 2004 | 03:50 PM
  #22
Rons2001GT's Avatar
Rons2001GT
one more question, where would I be able to find more information on targa tops too? how expensive are they to intall, and how much do you have to worry about the integrity of the actual car since you no longer have a roof on a car that was designed to have one?
Old Jul 5, 2004 | 08:08 PM
  #23
bigbadracer808's Avatar
bigbadracer808
ORIGINAL: Rons2001GT
when buying the kits, don't get suckered in by all the no cutting, no rolling, no welding, bolt on crap. it does require some minor modifications. inner fenders will probably have to be rolled. door tabs (don't actually know what they're called) have to be cut and a few other things. not really difficult to install by any means, though. but back to your question. with my kit, the doors actually open out and needs to be lifted up. keep in mind, though, the doors are heavy. it'll require some muscle to lift and pull down. on my kit, the doors actually rest on the a-pillar. not a big deal but may scratch up the paint. unless you're a ridiculously big guy, you can get by without always lifting the doors up. autoloc sells a universal deluxe kit that opens the doors up using actuators. i think they cost about $3000. might be a little cheaper. hope this helps ron.
Old Jul 6, 2004 | 12:16 AM
  #24
Reckless.Tim's Avatar
Reckless.Tim
I ♥ Acer
Hey BigBad, did you install your doors yourself? I found this site that has manual and automatic doors, have you heard anything about them? I was considering getting the automatic ones this spring, but I had questions as to wether they would work with my vert.
Old Jul 6, 2004 | 12:37 AM
  #25
bigbadracer808
hey tim. no, i didn't personally do them myself. i was at the shop for a while to watch them install the doors. like i told ron, there is no direct bolt on kit. even after installation. the kit needs to be tweaked for proper alignment and what not. decah.net, mrbodykit.com, and autoloc sell the kits that you linked to. i don't see any problems installing them on your vert. if i had enough cash, i would've gone with the automatic ones myself. go for it.
Old Jul 6, 2004 | 09:05 PM
  #26
kingsnake's Avatar
kingsnake
It's actually a single top, and it will fit in the trunk only if the rear seats are folded in. The kit comes with tie downs to secure the top in the trunk. You can check out the kit at http://www.jmsproductsinc.com/
Old Jul 6, 2004 | 09:13 PM
  #27
kingsnake's Avatar
kingsnake
The structural integrity of the car will be fine with a targa top as long as you tie up the subframe (good subframe connectors). If you don't tie up the subframe you might have some problems, but in general it is always a good idea to tie up the frame on a mustang anyway.
jerrytubes
Oct 23, 2015 12:11 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
Sixer4Life
Sep 29, 2015 07:03 PM
Sep 25, 2015 06:58 PM
