Wet sanding?
Old Sep 18, 2006 | 12:47 PM
PushinTheLimit's Avatar
PushinTheLimit
Default Wet sanding?
I was talkin to a guy about this and he said he had a friend to do it to his car and made it look incredible. I'm not really familiar with this so does anyone know more about it as a good idea or no? This would be to take out all the swirl marks in black paint.
Old Sep 18, 2006 | 05:43 PM
65coupe88hatch's Avatar
65coupe88hatch
Default RE: Wet sanding?
im not sure if thats a good idea, from what i understand wet sanding is done before the clear coat is sprayed so the next layer of paint is smoother. Why dont you try Meguiars SCRATCH X. that worked wonders on my dads all black ram 1500
Old Sep 18, 2006 | 06:36 PM
PushinTheLimit
I tried that but it didn't work so well for me. This is for the Cobra that I'm getting in a few months. Its very clean but I was just wonderin if I did start to get some swirls if wet sanding is a good option sometime down the road.
Old Sep 18, 2006 | 07:00 PM
CLEAN 03's Avatar
CLEAN 03
As an auto painter I wouldnt suggest wetsanding. Always try the less aggressive products before going that far. Swirl marks and scratches can most times be removed with a good polish. Compounding a car should be your last resort method if you cant get them out. Wetsanding your clearcoat will shorten the life of a factory paint job. If you have a repaint that has at least 3 coats of clear a light sanding job with water and 1500 or finer paper will give you that flat finish.
Old Sep 18, 2006 | 07:21 PM
Juztang's Avatar
Juztang
Do you have a Porter Cable polisher? I would give that a try with some polish before you try wet sanding. Most of the people that I've seen that have swirls can be fixed with some good swirl removers.
Old Sep 18, 2006 | 07:27 PM
CLEAN 03's Avatar
CLEAN 03
That man speaks the truth!
Old Sep 19, 2006 | 10:54 AM
PushinTheLimit
Oh yea... I would deffinetly try any and all polishing methods before I would resort to wetsanding. I just wasn't familiar with that process and I was wantin to find out more about it. The guy that I talked to about this said that his friend polished alot and eventually had more swirls than he liked so he tried a different alternative. He said after it was done that it looked better than it ever had but I guess it still takes the life away from the paint. Thanks for the info guys.
importsmasher
Oct 9, 2015 04:42 PM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
Sep 8, 2015 11:50 AM
SterlingStunner
5.0L V8 Technical Discussions
Sep 4, 2015 06:28 AM
NeoTokyo
Apr 11, 2004 12:57 PM
