what will a clay bar remove?
Old Sep 24, 2006 | 11:35 AM
svollmer's Avatar
svollmer
Default what will a clay bar remove?
Will it remove everything including wax and polish? Or will it just remove the imperfections in the paint?
Old Sep 24, 2006 | 01:15 PM
Juztang's Avatar
Juztang
Default RE: what will a clay bar remove?
Once you claybar you will have to rewax and polish. It is totally worth it. You won't believe all of the junk embedded in your paint.
Old Sep 24, 2006 | 06:24 PM
ZAXJAX's Avatar
ZAXJAX
The claybar will remove all the contaminates that have gotten embedded in your paint. It's a good idea to polish and wax afterwards. The claybar will leave your paint surface smooth as glass if done right. Definitely worht tkaing the time to do.
Old Sep 25, 2006 | 03:44 AM
Jim D.'s Avatar
Jim D.
Claying is not the same as colorsanding -- it won't remove orange peel or other imperfections.
But as already stated, it will safely remove contaminants that don't come off during washing, or even during polishing.
If got surface contaminants -- and I bet you do -- and if you've never used clay, try it... you'll be glad you did.
Check out the Mothers Clay Bar Reel which explains it pretty well.
Oh, and if you're near a Kragen (or probably also a Checker or Schuck's), it's on sale right now (at least in Southern California) with a newspaper circular coupon for only $14.99.
Old Sep 25, 2006 | 11:49 AM
02 JRClassic's Avatar
02 JRClassic
Claying the car is probably the best 3 hour investment you can do for your car. My car is going on 4 years old and had many imperfections imbedded in the paint. Definately a must for anyone is cares for their car as much as I do.
Old Sep 25, 2006 | 02:46 PM
Jim D.'s Avatar
Jim D.
I'll agree that claying is indeed about the best investment, period, especially at less than $20 for a kit that'll do your car two or 3 times.
If your car's neglected, it can take some time as 02JRClassic indicated, but a semi-annual claying shouldn't take more than an hour if you've been washing and waxing with any frequency.
I've seen lots of paint that's neglected and damanged by such contaminants, and these can discolor the clearcoat permanently -- a costly proposal if you realize just how expensive it is to repaint. Twenty bucks and a little time and your paint will not only last longer, but you'll get better results when you wax.
Old Sep 26, 2006 | 01:02 AM
svollmer's Avatar
svollmer
Thanks, I have done it before, and the results are quite amazing. I just didn't know if I was taking everything off of the paint or if I was taking only the impurities and leaving the wax or polish.
jwog666
Dec 27, 2021 08:09 PM
flash_xx
Oct 16, 2015 07:23 AM
Dathan
Oct 5, 2015 05:52 AM
fastbackford351
Oct 1, 2015 12:24 PM
winner99
Oct 1, 2015 10:52 AM
