Removing Rust Near Rotors
Old Sep 29, 2006 | 12:27 PM
barge's Avatar
barge
Default Removing Rust Near Rotors
I was wondering if any of you have removed rust like this. What kind of products should I use and what kind of results will I get? I think I got a little project on my hands!
Old Sep 30, 2006 | 03:10 AM
bigmik290's Avatar
bigmik290
Default RE: Removing Rust Near Rotors
ugh!!!!i dunno. definitly a project. armorall has some cleaner for break dust but it says its for your wheels. i dunno if you can use it on the brakes.
Old Sep 30, 2006 | 04:09 AM
barge's Avatar
barge
I'll probably just buy some new rotors. Found some cheapy ones on ebay.
Old Sep 30, 2006 | 10:48 AM
TPony's Avatar
TPony
The rust on the rotor per se should go away when you drive the car and apply the breaks. However, if it just rained and then you park it in the garage or even outside..in a couple of hours the rust will be back...it just a matter of metal oxidation. The rust on the rest of the rotor is another thing. Not sure if you can really get rid of it, unless you try cleaning it up and painting it...which I have not done myself, oh-by-the-way.
Old Oct 1, 2006 | 02:38 PM
barge's Avatar
barge
I take it this is a pretty common problem? It just sucks, when you have new chrome rims, then these ugly rusty titanic rotors behind them. I'll try to find a solution.
Old Oct 1, 2006 | 08:19 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
ORIGINAL: TPony
+1
Old Oct 2, 2006 | 02:05 AM
ScottY94GT's Avatar
ScottY94GT
My $1500 Brembo's rust as soon as I get done washing my car.....its not that big of a deal. Once you drive the car the brake area that the pad rubs will be spotless....as for the hub part of the rotor, find some high temp paint, whatever color you want, and paint the entire rotor or you can masking tape the pad region and paint the hub. No reason to really paint the back. Make sure you wire brush the rotors rust off completely b4 doing any painting and good luck! But if you want to replace the rotors....brembo makes cadnium plated rotors just like mine for oem, or stock, brakes.
[IMG]local://upfiles/34056/F4F2F1B09D5D496188C364228D186063.jpg[/IMG]
[IMG]local://upfiles/34056/BF850EEF4B604E828A6740E7D7AB8F68.jpg[/IMG]
Old Oct 3, 2006 | 04:21 AM
Jim D.'s Avatar
Jim D.
If you were using a spray-on, hose-off wheel cleaner, next time just spray it either directly on the wheels where you can, and onto an old sponge or mitt where you can't avoid the bare metals.
And maybe if you hit it with brake parts cleaner spray, it'll look less ugly.
Good luck!
jwog666
Dec 27, 2021 08:09 PM
b8checker
Oct 8, 2015 12:55 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
b8checker
Sep 30, 2015 07:11 AM
