Paint experts
I am getting ready to paint my stang this winter. I bought a 24 by 12 foot enclosed tent and sealed off the ground with plastic and plywood. I was curious as to what kind of paint i should use, Should i use two or single stage paint. I was thinking of a silver metallic with black stripes. also where would be the best place to put an exhaust fan?
Matt
Matt
Use some furnace filter on the fan, I would put the fan low so that the fumes/over-spray does not get up into the air. Remember to put a filtered inlet for fresh air as well. As for paint I like PPG but I have had good luck using stuff from www.autopaintdirect.com . Whatever you do, keep all your supplies from the same company, do not mix primer from PPG and color from Dupont etc. If this is your first paint job I am going to suggest that you stay away from metallic paint, it's harder to spray. You can go base/clear or single stage, but single is easier and cheaper.
thanks for the reply, I was also curious as to what paint i should use, Urethane or acrylic enamel or synthetic enamel? What is the difference? I have painted a little bit before and have done metallic colors, but its just my first time in a home made spray both. Thanks alot
Matt
Matt
ORIGINAL: sowaxeman
I heard of some people wetting down the floor to help trap the overspray/dust. Is there any validity to this [&:]
ORIGINAL: JD1969
Yes it will help keep dust down, but the downside is that all the extra moisture willl make the paint dry slower, and you run the risk of splashing water on the car.
ORIGINAL: sowaxeman
ORIGINAL: moparmatt89
Matt
Matt
Oct 1, 2015 09:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
mungodrums
Sep 28, 2015 10:54 PM
