Meguiars Scratch X is amazing Look:
Old Jan 3, 2007 | 08:27 PM
Quicktime_GT's Avatar
Quicktime_GT
Default Meguiars Scratch X is amazing Look:
I used Meguiars Scratch X on some scratches before I put my SS letter inserts on and it works great.. check it out:This is the stuff I used:
Old Jan 3, 2007 | 10:06 PM
ts91stang's Avatar
ts91stang
Default RE: Meguiars Scratch X is amazing Look:
glad you had good luck with it. i usedit and it didnt do a thing.
Old Jan 4, 2007 | 01:53 AM
WhiteStallion06's Avatar
WhiteStallion06
same here i used it once and didnt help me much at all how much did you apply? i heard you gotta apply so much that the scratch cannot be seen when your buffing it
Old Jan 4, 2007 | 11:25 AM
ZAXJAX's Avatar
ZAXJAX
If you use a PC with it, it's not that bad to use! You do need to use some elbow grease if your doing it by hand.
Old Jan 4, 2007 | 01:02 PM
Dan04COBRA's Avatar
Dan04COBRA
Is an actual abrasive or is it one of those scam scratch removers that has fillers to make the scratch appear to be gone, wash it once and it's back?
Old Jan 5, 2007 | 05:16 PM
Quicktime_GT
Not sure how it actually works.. but I used it just as you would wax. Only I would apply a layer let it dry some then rub pretty hard. I repeted this probably 5-7 times er so.
Old Jan 5, 2007 | 11:09 PM
TPony's Avatar
TPony
ORIGINAL: ts91stang
+1...mine is collecting dust somewhere in my garage...
Old Jan 5, 2007 | 11:27 PM
Stickman81's Avatar
Stickman81
Well done.
Old Jan 5, 2007 | 11:31 PM
Stickman81's Avatar
Stickman81
ORIGINAL: Dan04COBRA
To my knowledge, Scratch-X does not contain fillers and is a"Light-cut" abrasive.
Several folks have had great results with the product which is now re-formulated for use the PC. The new formula reportedly prevents clogging the pads during use.
Old Jan 6, 2007 | 06:30 PM
GT Newbie's Avatar
GT Newbie
I just tried it this morning on some very minor "scratches" and a small "hazy/greasy" spot where I'd rubbed off some fresh bird crap with a kleenex, and it didn't do JACK for the miniscule scratches- and only helped a tiny bit (maybe 1/3 less at the very MOST) on that "hazy" spot!
VERY disapponted and pissed-off at the results, needless to say...![>:]
