liquid clay bar
Old Feb 25, 2007 | 04:23 PM
Jim D.'s Avatar
Jim D.
Default RE: liquid clay bar
ORIGINAL: 99 GT vert
i talked to a guy at auto zone last night and he said that it will do the same as the regular but i was not gonna buy that excuse he was just trying to make a sale
It's always good to know someone's experience with a particular product when assessing his alleged expertise. Has he tried the two side-by-side?
Old Feb 25, 2007 | 05:21 PM
99 GT vert's Avatar
99 GT vert
ORIGINAL: Jim D.
the guy told me that he has not used it but people told him i tdid a better job that the regular clay bar
Old Feb 25, 2007 | 05:37 PM
Cooter's Avatar
Cooter
I just dont see how a product calling itself a liquid claybar could do any beter than a claybar. I dont see how it would pull stuff out of the paint like a claybar would.
Old Feb 25, 2007 | 11:35 PM
99 GT vert's Avatar
99 GT vert
ORIGINAL: Cooter
+1 it just dosent seem possible
Old Feb 26, 2007 | 12:49 AM
03machyellow's Avatar
03machyellow
how easy is it to use a clay bar? can you mess anything up?
Old Feb 26, 2007 | 12:54 AM
goathead75's Avatar
goathead75
It's extremely easy. As long as the car is clean and you use enough lubricant you'll be fine. Just simple common sense type stuff, like if you drop it on the ground in a pile of sand, throw it out. Make sure the car has been just washed thoroughly and is clean. The only way to damage the paint is if you don't use enough lubricant and you're draging a lot of grit across the paint. You won't have a problem, it's a very simple process.
Old Feb 26, 2007 | 01:55 AM
03machyellow
do you dry the car then use the lube with it?
Old Feb 26, 2007 | 04:24 AM
Jim D.'s Avatar
Jim D.
ORIGINAL: 03machyellow
Yes. Traditional clay bars are all used the same way... here's a helpful little video that explains it... http://www.mothers.com/reelworld/mothersclay.html
Old Feb 26, 2007 | 02:02 PM
goathead75's Avatar
goathead75
I've heard of people doing it with the car wet and even while they're washing the car. I wouldn't and never have. I think it would be more thorough to dry it off though and then use either a quick detailer as lube or a spray bottle with soap and water in it.
Old Feb 27, 2007 | 01:12 AM
924banger's Avatar
924banger
I have been using the liquid clay bar. I can tell a big difference...but that might be because it looks like the first serious detail job the car has ever had[>:]. I can see streaks(cleanest part)were I used my fingers instead of my palm. The next time I am in town I am buying an actual clay bar kit.
Yeah rubbing compound of some sort should take the white water spots out.
