Window tinting 07 windows
Old Mar 29, 2007 | 10:35 PM
chemoman's Avatar
chemoman
Default Window tinting 07 windows
Does the auto window need to disabled while the tint dries and is this even possible? Any how to's would be appreciated.Is 07 the only year that does this?
Thanks in advance.
Old Mar 29, 2007 | 11:29 PM
Scotty07's Avatar
Scotty07
Default RE: Window tinting 07 windows
Don't know about that....but be careful to install felt / moleskin so the tint does not get scratched up
Old Mar 30, 2007 | 03:01 AM
raubt's Avatar
raubt
ORIGINAL: chemoman
Thanks in advance.
All the S197's do the auto up/down thing.
It can be disabled (how-to in your owner's manual) but I'm not sure if you need to disable it when installing tint. I haven't heard about anyone else on here disabling that when getting tint, so the distance it travels might be short enough that it doesn't matter. Mention the auto up/down to the person doing your tint and see what they say about whether or not you need to disable it.
Also, like Scott07 said, make sure you install moleskin. http://www.tintprotector.com/ You can do it yourself, or maybe get your tint place to install it for you, but that stuff will prevent your tint from scratching (although there are people who've tinted without putting on moleskin, and their tints are fine, so it's not 100% that your tint will scratch without it) so it's a good idea.
Another tip: 20% or darker. That light *** 35% just doesn't cut it.
Old Mar 30, 2007 | 07:24 AM
TPony's Avatar
TPony
Hmmmmm..I did not disable mine and it turned out AOK.
Old Mar 30, 2007 | 12:15 PM
chemoman's Avatar
chemoman
Here's what the tint store says. They "trick" the door to think that it is closed. I guess trip the latch. Who knows. That keeps the window up while tinting. Then they heat dry the tint so that the auto drop can operate normally. As far as scratches, the tint comes with a lifetime warranty. I guess It'll be worth lettin a professional do this.
35% rear 20% driver and passenger. Texas law.
Thanks ya'll.
Old Mar 30, 2007 | 11:12 PM
tritonpwrd's Avatar
tritonpwrd
yea my tint came with lifetime warrenty also but these cars do scratch tint just from normal use. Mine were scratched 2-3 weeks after i had them done. I had them retinted under warrenty but this time I installed moleskin which is basically a special felt and they have been perfect since.
The place I had mine done heated the bottom of the tint to cure it so that it would be ok with the auto up and down.
Old Mar 31, 2007 | 02:19 PM
chemoman's Avatar
chemoman
All good info. thanks. Looks like moleskin it is!
Old Apr 1, 2007 | 07:10 PM
chemoman's Avatar
chemoman
Can you only get moleskin on line? The tint store man had never heard of it. He also said that he had no complaints of mustangs scratching tint.
Old Apr 2, 2007 | 12:41 PM
SOLDSHORT's Avatar
SOLDSHORT
my tint shop said the auto up down is not a problem.
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
chrisdbassplayer
Oct 13, 2015 06:53 PM
DreadPirateRoberts
Sep 26, 2015 02:11 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
