91 hatch gas shocks
Old Apr 9, 2007 | 12:05 AM
Epic91GT's Avatar
Epic91GT
Default 91 hatch gas shocks
what is the gas shock info needed to find replacement or can i just adjust my current ones
the problem i am having is that every now and then when i put the hatch up it will close on its own
ne advice?
Old Apr 9, 2007 | 11:02 AM
sowaxeman's Avatar
sowaxeman
Retired Moderator
Default RE: 91 hatch gas shocks
Those should be easy to find at any auto parts store, but if I recall they are pretty expensive.Or try 50resto.com There aren't any adjustments. If you are too cheap to buy new ones there is a way to fix them so your hatch will stay up. Raise the hatch and prop it open with something - then take a hammer and hit each gas shock in the middle JUST ENOUGH (don't destroy it [8D]) to put a slight bend in it. Now when you raise the hatch it will be beyond the bend and hold it up . But it won't help the fact that the hatch is heavy and not the easiest thing to lift
Old Apr 9, 2007 | 12:23 PM
Epic91GT's Avatar
Epic91GT
yeh it is hard holdiong it up with one hand and putting **** in the back thanks for the info though
4cylinderplus2
Oct 9, 2020 07:45 PM
baddog671
Jul 26, 2016 01:20 PM
b8checker
Oct 8, 2015 12:55 PM
UrS4
Oct 3, 2015 06:23 AM
b8checker
Sep 30, 2015 07:11 AM
