Brakes on 83'
Old Dec 1, 2004 | 01:24 PM
83MercCapri's Avatar
83MercCapri
Default Brakes on 83'
I didn't see a spot to put this so i'll ask here. I've driven this thing a round the last couple days trying to see what i need to do to get it runnin well. When i hit the brakes hard the back left tire locks ups. I also missed an exit yesterday on the highway. The brakes might need some real work or i was just driving to fast. What makes the back left lock up like that. Is there a way I can adjust the pressure or something?
Thanks,
Bret
Old Dec 1, 2004 | 04:11 PM
dc_mann8's Avatar
dc_mann8
Default RE: Brakes on 83'
your axle seal could be gone.. i BELEIVE this will cause a tire to luck up.. verrrrrry dangerous in winter. someone correct me if im wrong, but take the rear tires off and check the brakes for oil
Old Dec 1, 2004 | 05:44 PM
fast83gt's Avatar
fast83gt
Could just be a totally toasted brake back there. The easiest way to find out would be to take off the tire and brake drum and have a look.
Old Dec 5, 2004 | 10:22 PM
83GT306's Avatar
83GT306
ORIGINAL: 83MercCapri
Thanks,
Bret
You might have a binding e-brake lever or cable, or even a warped drum. I'd go ahead and just tear into the whole rear braking. Replace the wheel cylinders, shoes, new hardware, and take the drums into somewhere and have 'em measured and turned, or replace 'em.
But also, it could be an issue with the front brakes, a seized caliper etc...causing more braking action to be applied to the rear.
It shouldn't cost an arm and a leg for all new brakes if you do it yourself.
[IMG]local://upfiles/10806/E18131E306CD4658B77460F929482FA7.jpg[/IMG]
Old Dec 6, 2004 | 12:11 AM
Acer2428's Avatar
Acer2428
Site Mod
w00ty w00t!!! You're an awesome addition to the site... Once again, welcome aboard!
b8checker
Oct 8, 2015 12:55 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
