Spraying Pattern??Pls Help
Old Apr 24, 2007 | 06:50 PM
SilvrStang's Avatar
SilvrStang
Default Spraying Pattern??Pls Help
Ok guys I was wondering what is the best spray patern,vertical or horizontal when touching up on some paint. Is there a can that u can put paint in and start spraying?? If yes where can i get it
Old Apr 25, 2007 | 02:49 AM
Blckstng93's Avatar
Blckstng93
Default RE: Spraying Pattern??Pls Help
Side to side i spray vertical. Up and down i sprayhorizontal. Follow any curves as you paint them for an even coat.. Yes you can get a can and put paint in, just use an airbrush or a paint gun.
Testors has an acrylic paint set with an air can and a spray nozzle you hook up to a lil bottle. I got one for $8 at Walmart. Just use your own paint in the bottle. Cheap but effective for small jobs like paint chips. Mix the paint real good and thin it if needed. practice a bit and you should be fine.
Tivo304
Aug 28, 2023 12:19 PM
guitarman376
Oct 11, 2015 01:47 AM
mdg
Oct 1, 2015 07:04 AM
pimp2303
Sep 17, 2015 08:45 PM
Sep 8, 2015 11:50 AM
