flat black
Old Jun 2, 2007 | 12:09 AM
shicaca's Avatar
shicaca
Default flat black
How would youpaint a 19875.0flat black? I have an air compressor. Should i buy a gun and some paint and spray it that way? Or could i get away with a bunch of store boughtspray paint. Does anyone have expierence with this? I dont really care about a completly professional paint job, but i dont wantit to look like complete ****.
Old Jun 5, 2007 | 05:14 PM
foxmagic91's Avatar
foxmagic91
Default RE: flat black
Your best bet is to buy a gun and spray it with real automotive paint if you want it to last awhile. You can get a decent finish out of a spraycan but it wont last long out in the sun. Whichever route you go be sure to prep the car properly or neither will stick. When i did the Riv I just scotch-brited the whole car till it was all scuffed up, wiped it down with acetone to clean off all the leftover wax and dust, then wiped it with a tack cloth to remove any lint, and sprayed. I used acheap black paint I got from the local auto body supply shop and a couple of coats of satin clear coat to keep it from getting chalky. All togher without the gun it was under $500. If I had to do it again I would have used an epxoy primer under it to give it something better to stick to and to keep the bodywork from showing through. Good luck.
Dathan
Oct 5, 2015 05:52 AM
mungodrums
Sep 28, 2015 10:54 PM
Sep 25, 2015 09:06 AM
uberstang1
Sep 20, 2015 06:42 PM
aleit2013
Sep 4, 2015 11:58 AM
