Mr. Clean Auto Dry
Old Jun 21, 2007 | 08:10 PM
UMTerp2010's Avatar
UMTerp2010
Default Mr. Clean Auto Dry
Whats the verdict on this, I wanted to try it but I've been cautious. Any one here use it?
Old Jun 21, 2007 | 08:36 PM
Stims's Avatar
Stims
Default RE: Mr. Clean Auto Dry
I tried it when it first came out. Results were so-so. We have hard water, so the filter didn't last very long and got too expensive to keep replacing it. Plus I had to do some scrubbing to get some dirt spots off. Maybe someone else has had better exprerience with it, but IMO it's not worth it. btw, I used it on my old unwaxed jeep. Maybe it works better on a newer waxed car
Old Jun 21, 2007 | 10:14 PM
jslove1408's Avatar
jslove1408
I like mine I think it works pretty well but I still towel dry I just use it as convenience.
Old Jun 22, 2007 | 12:01 AM
WhitePony02's Avatar
WhitePony02
You aren't getting it clean. It's just like filling up a bucket with car wash and filtered water, then tossing it on your car. But you have to towel dry it that way. It's not getting any cleaner though, if anything you're better off throwing the bucket full on your car and hand drying it. You'll actually be touching it and loosening up the dirt. I just don't think it's worth it unless you're extremely lazy.
Old Jun 22, 2007 | 01:27 AM
Abom's Avatar
Abom
Complete piece of ****. I tried it when I was detailing for a car dealership. It did cars semi-OK, but bullsh!t on not leaving water spots on glass, I got TONS of water spots on some brand new cars [:@]Also a big piece of **** to use on ATVs, scooters, snowmobiles, etc, it leaves MEGA water spots on plastic.
Old Jun 22, 2007 | 03:00 AM
dodgers's Avatar
dodgers
Got mine for Fathers Day. Cant say anything bad about it. Used it in a cool shaded area and worked as advertised. Will keep using and would give it an A plus.
Old Jun 22, 2007 | 03:42 PM
rogan01's Avatar
rogan01
Used one for about 2 years and just got a new one. What I like about it is that you don't need buckets. The"autodry" part is so-so. I now have a silver car so don't notice much but when I had red and black (especially) it did leave some visible water marks. I had to towel dry some after. You also have to replace the water filter after about 3 uses (even though it says about 5-6). The filtered water stream is sort of fine - not a lot of pressure - but I guess that is how it needs to work.
Overall, like I said, I use it for the convenience of not having buckets.
I think you have to use the special soap - wonder if you can use another soap?
Old Jun 23, 2007 | 06:15 PM
outpost77's Avatar
outpost77
I'v had both versions and both work as advertised. It cleans the car well and I have had no water spots at all. As it dries, I go over the car with a micro fiber cloth to take care of drips off the louvers, mirrors and the like. I have given it as a present to other car nuts and they have told me it works great for them too. I highly recommend it. BTW, I'm a Terp fan too. Maybe we use the same water.
Old Jun 25, 2007 | 02:08 PM
03machyellow's Avatar
03machyellow
works good if in a cool shaded spot, but man it didnt work out in the sun. there where tons of water spots.
Old Jun 25, 2007 | 03:10 PM
rogan01's Avatar
rogan01
Are there 2 versions?
ORIGINAL: outpost77
