Cleaning the engine
Old Jan 21, 2005 | 12:02 AM
MLMike25's Avatar
MLMike25
Default Cleaning the engine
What is the best way to clean the engine parts (exterior). Its pretty clean now but I wanna make sure I keep it that way. Any suggestions?
Old Jan 21, 2005 | 11:44 AM
brando5.0's Avatar
brando5.0
Default RE: Cleaning the engine
When I clean an engine, I use Zep Formula 50. I liberally spray down the entire engine compartment, and the underside of the hood. Then, I let it sit for a couple of minutes. After that, hose it down. A lot of the times I use a pressure washer turned down low, but a garden hose should work just the same. Most engine cleaners you buy say to use as little water as possible, but by only using a little bit, you still will leave some cleaner behind, and, in the case of foamy engine brite, you wil also leave behind a white film. You might want to cover important electronics (computer & alternator), but it isnt always required. After that, if you want the hoses really shinny, use tire shine. Spray the shine on a rag and then wipe them down. Just make sure to let the tire shine flash off for a little while before running the engine- most tire shine is flamable while wet.
Old Jan 21, 2005 | 12:18 PM
code3GT's Avatar
code3GT
Mustang Nazi
Use CD2, it is a 2 step process that makes then engine look new.
Nick Oliver
Oct 17, 2018 04:22 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
zachary1988
Sep 4, 2015 03:04 PM
5.0 kevo
Sep 3, 2015 06:24 PM
Sep 1, 2015 08:16 PM
