Two Year Old Stripe removal
Old Aug 22, 2007 | 12:47 PM
SatchDogUSA's Avatar
SatchDogUSA
Default Two Year Old Stripe removal
Hi Guys,
Anyone else have a torch red 05 mustang and removed the stripes from the doors…Recently? I say recently as I’m curious to know if not only did they come away cleanly after been on for a couple of years, but also was there a color fade that made it look worse than before you started?
Not curious about how….curious about was it worth the effort?
Old Aug 22, 2007 | 08:49 PM
02WhiteGTVert's Avatar
02WhiteGTVert
Default RE: Two Year Old Stripe removal
it will probably take some of the paint off with it.
Old Aug 23, 2007 | 09:27 PM
ktm300's Avatar
ktm300
If you use an eraser wheel you can easily take off any vinyl graphics, pinstripes etc. Use it on a geared cut off style grinder, it has to be geared and not go over 3k Rpm! Normal die grinders are 20k Rpm+ and will not work. Chances are the clear underneath the stripe will be a slightly different shade, there isnt too much you can do about that. You could try water sanding with 3000 grit and then polishing it out.
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
FivePointToTheOh
Oct 2, 2015 04:09 PM
spamedic
Sep 9, 2015 12:15 AM
Doogie65
Sep 6, 2015 02:55 PM
cbird1177711
Sep 2, 2015 04:12 PM
