HEAT WRAP
Old Sep 16, 2003 | 09:18 PM
95Stealth302's Avatar
95Stealth302
Default HEAT WRAP
Where can I get heat wrap, and how do I put it on?
Old Sep 16, 2003 | 09:20 PM
Black Horse's Avatar
Black Horse
Default HEAT WRAP
Summit Racing!!!!!!!!!!...Hard to do with headers on car....basically you just remove them and wrap up the primary tubes all the way down to the collector...<IMG src=smileys/smiley1.gif border="0">
Old Sep 17, 2003 | 12:05 AM
95Stealth302
Default HEAT WRAP
Thanks
Old Sep 17, 2003 | 04:46 PM
Redline5th's Avatar
Redline5th
Default HEAT WRAP
hey 95 stealth, what times are you running with those mods?
Old Sep 17, 2003 | 06:08 PM
95Stealth302
Default HEAT WRAP
I'm not to sure, I havn't had a chance to get to a track beacause I just put the new clutch in replacing the ORIGINAL clutch at 159000 miles, this car was babied by the original owner, sweet. Anyway, Im not sure, what kind of times do you run in your saleen, if that's your car in the picture.
Old Sep 18, 2003 | 09:39 PM
Dan04COBRA's Avatar
Dan04COBRA
Default HEAT WRAP
Also, don't let the header wrap moisture myth strike any fear in you. Your motor will blow up and your house will burn down before a set of headers on a street car rot out if it's not a winter car.
Old Sep 23, 2003 | 01:52 AM
94kbscobra's Avatar
94kbscobra
Default HEAT WRAP
yeah ive heard of the header wrap theory too, wear since only the outside is wrapped it will rot fromt he inside out. the high temp coating companies make these claims and say that the only good way to coat them is in and out to prevent that.
Old Sep 23, 2003 | 04:47 AM
Dan04COBRA's Avatar
Dan04COBRA
Default HEAT WRAP
Yep, go ahead and wrap them as long as she won't be a winter beast!!</P>
I've been using header wrap on a set of long tubes on a big block dirt modified, that runs on dirt (clay actually) and they use calcium to treat it, and we all knows that will increase the rate at which metal rusts by ten fold...we've had the same set of headers for 4 seasons now!!! No problems.</P>
PaulH2
20
Jan 31, 2016 09:48 AM
Explosive
Oct 2, 2015 07:45 AM
folivier
Oct 2, 2015 05:34 AM
Sep 18, 2015 06:49 PM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
