Scratches???
Old Feb 20, 2005 | 05:59 PM
94droptop's Avatar
94droptop
Default Scratches???
I have a 94 convertible and i hate the minor surfaces scratches all over my car? I dont know how they got there. They range from surfarce to a few deep ones? any good products out there to make my baby shine?
Old Feb 20, 2005 | 09:10 PM
Vash the Stampede's Avatar
Vash the Stampede
Default RE: Scratches???
its a long shot, but... really fine grit sand paper.
Old Feb 21, 2005 | 12:10 AM
BaltimoreStreetMods's Avatar
BaltimoreStreetMods
A lot of people swear by maguires polishes, but I have not tried it firsthand. Ya might check to see how much the paint shop would charge for filling the minor scratches and redoing the clearcoat
Old Feb 21, 2005 | 12:51 AM
Jimmz's Avatar
Jimmz
You can try and buff them out, but if that doesnt work you will need to color sand it... color sanding wont work if u can feel the scratches with your nail. Worse case scenario you can touch it up with touch up paint, or get it repainted. But just know that your always going to get scratches no matter what you do..
Old Feb 21, 2005 | 01:16 AM
mattwilliams's Avatar
mattwilliams
Check the multi-stage meguiars wax/buffing kit. We use it in my college auto bady class and its amazing. either buy an electronic buffer, or find someone who has one and do this. Your car will SHINE, and it will take the scratched out, except for major ones. but it will work.
Old Feb 21, 2005 | 01:18 AM
Chanedeezy4106's Avatar
Chanedeezy4106
I had the same problem someone keyed my car their was this stuff that colored the scratch! Kinda worked
Old Feb 21, 2005 | 06:52 PM
xRockThePonyx's Avatar
xRockThePonyx
I've used the Meguiar's scratch stuff and usually buff the car when I use that as well. It always helps, but I've had to use it a few times over one area to get it to make any difference.
Old Feb 21, 2005 | 07:18 PM
vfast's Avatar
vfast
I ♥ Acer
that stuff works great on fine scratch
they used to make this stuff called "pink corral" came only in a gallon can
Old Feb 24, 2005 | 12:35 AM
Jimmz's Avatar
Jimmz
OUCH Chanedeezy someone HATES YOU!!, yeah if its deep your best bet would be to paint it, expensive but its the right way... and only way to get the scratch out permanently
Old Feb 27, 2005 | 02:56 AM
birdman076's Avatar
birdman076
Meguiars makes stuff called "scratch X" that works well for small scratches. I did my black avenger with an electric buffer and foam 3M pad. But for the heavy scratches or alot of small ones I would wet sand the car with 2000 grit wet/dry 3M sand paper. Do yourself a favor and wash the car very well 1st, then run a constant trickle of water over the area as you are wet sanding or you will load up the paper and it will make new scratches with the crap collected on it. Wet sand one panel at a time then buff it with 3M professional Polishing compound. 1 bottle usually cost about $14 at NAPA or a painter supply store its great stuff comes in liquid and works magic. Then wax over top of it with your favorite wax. Oh and 1 more thing, when you wet sand do not use pressure as you will leave finger marks in the paint!!!!!
