Scratches???
ORIGINAL: birdman076
Oh and 1 more thing, when you wet sand do not use pressure as you will leave finger marks in the paint!!!!!
For light scratches, using really fine sandpaper and a buffer will work great. I use 2500 grit. A sanding sponge or foam block work great for under the paper. Wetsand the scratches. Mixing a small amount of soap in with the water will help the sandpaper slide easier, and leave a better finish. Come back with a very fine compound to take off the high spots left over from the wet sanding.
Personally, I'm against most of the scratch removal polishes. By me experiance in a detail shop, they mostly just temporarily hide the scratch.
You shouldnt need to have the car repainted. That seems like overkill. If you dont want to try the buffing yourself (which i recommend against, unless you've done it before, because of the chance of leaving swirl marks) I would leave it to the professionals. Most auto body shops around here will run about 300 for an entire outside scratch removal/buff, but if there are detail shops in your area, check with them. I usually charge about $100 for buffing/scratch removal of entire vehicle.
I bought a product that as of yet I haven't tried but it's supposed to do a great job at what you're trying to do.
Langka Corp.
The product I ordered might work for the major scratches and any stone chips you might have...
I'm waiting for the weather to clear before I do the paint repair but I'm betting it'll work.
Try www.langka.com
I'll try to get a website and post it..
Langka Corp.
Try www.langka.com
CarGuyZM10
Aug 31, 2015 07:08 PM
DrunknRuckus
Aug 23, 2015 10:05 AM
