Whats waxing?
Old Oct 3, 2007 | 05:02 PM
Stangn00b's Avatar
Stangn00b
Default Whats waxing?
Hey everyone i got myself a yellow mustang and i am tring to make the paint shine. Well i have a few questions. What is waxing? Do i need to buy special equipment? Costly? Would it help my car?
Can i use it on the lights windows etc.? Your answers will be greatly appreciated thanks
Old Oct 3, 2007 | 05:20 PM
Hawaiianbro's Avatar
Hawaiianbro
Default RE: Whats waxing?
um....waxing as in after you wash and dry your car you wax the car to protect it from rain/uv rays/acid bird poo. dont wax the lights that may leave a residue as well any plastic or rubber. wax isnt exspensive maybe what 2-5 bucks depending on brand? I use the mothers clay bar and wax kit. I think its around 8-10 bucks but it cleans the paint nicely. but dont glob alot of wax use enough at a time to spread on a even area. after it sits for a minute or so rub it off.
hope that helps
Old Oct 3, 2007 | 06:18 PM
sowaxeman's Avatar
sowaxeman
Retired Moderator
Wax is a paint protectant. It helps the paint shine, stay smooth, bead water, all mentioned above, etc... The key is learning what all the different chemicals do. You've come to the right place as there are several very knowledgeable Detailers in here that love to help out. But in a nutshell:
Step 1 - Claybar: removes contaminates from your paint/clearcoat (even new cars) and leaves it smooth as butter.
Step 2 - Compound/Swirl Remover: for older or neglected paints, as the name says it removes swirls and other MINOR paint boo-boos. This step can be skipped on newer cars or paint that is well cared for
Step 3 - Polish: never skip this step, this is what nourishes your paint, makes it look rich and shiney
Step 4 - Wax: this protects your paint as mentioned above, as well as all the hard work you put into the first few steps - usually the last step.
Some will add a step of Glaze in there before the wax - your preference.
Old Oct 3, 2007 | 08:26 PM
TPony's Avatar
TPony
^ Well said...exactly.
Old Oct 3, 2007 | 08:58 PM
Stangn00b's Avatar
Stangn00b
Wow thank you for your details in your replys!
btw are all these some form of liqid?
Old Oct 3, 2007 | 09:02 PM
Juztang's Avatar
Juztang
Yes a claybar is actually a bar of clay. You use a quick detailer of specific clay lube and lubrication, then you just let the claybar glide over the surface. There is no need to apply an pressure. At first the surface will feel rough or grab then once the claybar starts doing its job it will slide over the surface with ease. After you are done claying your paint will feel so smooth.
I actually carry a 4 oz. elastic claybar as well as the claybar and quick detailer as a lube that comes in a kit together if you are interested.
Old Oct 3, 2007 | 09:13 PM
Stangn00b's Avatar
Stangn00b
is there any precautions i should take before waxing?
Old Oct 4, 2007 | 09:05 AM
99 GT vert's Avatar
99 GT vert
make sure you wah you car is about it
Old Oct 10, 2007 | 09:56 AM
Hawaiianbro
ya wash your car; the worse thing you can do is try and polish/wax your car without washing it.
Mr. D
Sep 17, 2015 08:17 AM
Aznxwidxmustang
Jun 24, 2005 01:32 PM
ParrotHead
Sep 1, 2004 09:35 PM
atlantic pony
Sep 17, 2003 12:17 PM
