removing old wax
Old Oct 20, 2007 | 12:55 PM
hotrod351's Avatar
hotrod351
Default removing old wax
well it looks like i waxed my 70 mustang way to many times and now, after i wash it, it looks dull and scratchy, i used some polishing compound on the truck to remove the wax buildup and it looks pretty good but what a long hard job. i still have to do the top and hood. any recommendations on a good way of removing built up wax without hurting the paint.
Old Oct 20, 2007 | 12:58 PM
Juztang's Avatar
Juztang
Default RE: removing old wax
A good cleaner polish will remove any layers of wax you might have on the paint. My Light Polish and Poorboys SSR1 will both work well by hand. These will also bring back your shine and reflection. Then just top with a wax to protect.
Old Oct 20, 2007 | 01:09 PM
hotrod351's Avatar
hotrod351
thats what i figured, right now im using meguiars #2 compound. not a lot of fun but at least im getting results.
Old Oct 20, 2007 | 01:31 PM
SVTBill's Avatar
SVTBill
also to remove the wax you can use either dawn dish soap or a clay bar, but after you remove it you will still have a dull finish most likely, thats where justin's polish and wax/sealant comes into play
Old Oct 20, 2007 | 08:22 PM
hotrod351's Avatar
hotrod351
well so far the meguiars #2 compound seems to be working great and its leaving a mirror finish. guess i learned not to wax my car every couple weeks.
Old Oct 20, 2007 | 08:45 PM
99 GT vert's Avatar
99 GT vert
ORIGINAL: hotrod351
you can wax about every 2 to 3 weeks that is what i do you just want to use a polish with them a couple times a year
Old Oct 21, 2007 | 06:48 PM
hotrod351's Avatar
hotrod351
well i don't know exactly what i did wrong but what ever i applied to my car really built up and seems to have just sat there. might of been to hot outside when i applied it. the problem is only on the trunk, hood and top, not on the sides of the car. im going to try dish soap to remove it, if that doesn't work i know polishing compound will do the job.
Old Oct 22, 2007 | 07:35 AM
Danase's Avatar
Danase
Are you doing this by hand?
Compound is not somehting you want to use to remove wax. Compounds are aggresive and over kill for wax removal. I just spray on some Stoner Tarminator and it will remove your wax. Then if you want to bring back the shine a light polish like Swirl Abolisher I, follow with Danase Wet Glaze, and top with a high quality wax or sealant.
It might sound like a lot but trust me when I say all of these products and steps will be MUCH easier to use than the compound you are using right now and will give superior results.
Old Oct 22, 2007 | 01:38 PM
hotrod351's Avatar
hotrod351
isn't there something that i can buy at checker that would be the same as this Stoner Tarminator. and yes im doing it by hand.
Old Oct 22, 2007 | 01:49 PM
hotrod351's Avatar
hotrod351
just checked and checker does carry it. ill give it a try. the more i think about it the more i think i put the wax on when it was to hot out. ill post back with the results of the stoner tarminator product.
