Stained pad
Old Oct 24, 2007 | 11:19 PM
SVTBill's Avatar
SVTBill
Default Stained pad
i have a orange light cutting pad, white polishing pad and grey finishing pad
well today i was using PB ssr2.5 on the orange, OD light polish on the white and OD wet glaze on the grey (all products worked great)
i got really busy really fast and couldn't wash the pads for about 5 hours and now i can't get the stains out..the 2.5 came right out of the orange pad easily and the glaze came out mostly but the light polish has stained the white pad, i tried hot water and dish soap and that got some out, but not all
what are some other cleaning methods that i can use that wont take a hard toll on the pads? thanks
Old Oct 25, 2007 | 07:51 AM
ZAXJAX's Avatar
ZAXJAX
Default RE: Stained pad
Snappy pad cleaner will work or use a Simple Green and dish soap mixture and let them soak. Rinse them with clean warm water and you should be good to go.
Old Oct 25, 2007 | 08:28 AM
sowaxeman's Avatar
sowaxeman
Retired Moderator
Not sure you will get them totally clean, but as long as you are cleaning them and getting the gunk and grime out of it (with the simple green) they should be clean enough to use again.
Old Oct 25, 2007 | 08:46 AM
Danase's Avatar
Danase
Don't worry about it. All of my pads are stained. It doesn't effect the pads performance in any way shape or form.
mungodrums
Sep 29, 2015 09:18 PM
mungodrums
Sep 28, 2015 05:45 AM
Ghost_Conscience
Sep 23, 2015 02:17 PM
