Engine Cleaning
Old Mar 7, 2005 | 09:05 PM
fastmustangs1's Avatar
fastmustangs1
Default Engine Cleaning
Does anyone recommend something to clean the engine up. My stang is going into the show and the engine looks
like crap.
Thanks,
Matt[:@][:@]
Old Mar 7, 2005 | 10:21 PM
vfast's Avatar
vfast
I ♥ Acer
Default RE: Engine Cleaning
I use simple green
Old Mar 7, 2005 | 11:02 PM
jdaniel's Avatar
jdaniel
I ♥ Acer
I just use the stuff at the carwash. Spray it on and let it sit for 10 seconds and then wash it off. Looks brand new.
Old Mar 7, 2005 | 11:15 PM
Martinrulz's Avatar
Martinrulz
Daniel do you cover anything before sparying cleaner and washing it down? Like the distributor or anything? I got some stuff from the dealership and they said remove the air cleaner and cover the distributor with plastic...
Old Mar 8, 2005 | 02:44 AM
mikev08826's Avatar
mikev08826
I ♥ Acer
ORIGINAL: Martinrulz
O.K. This is a common misunderstanding...YOU DO NOT HAVE A DISTRIBUTOR. Only carbeurated ahve distributors.
Spray with simple Green or Wheel cleaner, let sit for a min...then pressure wash the solvent off. Just avoid spraying the alternator.
Old Mar 8, 2005 | 02:45 AM
mikev08826's Avatar
mikev08826
I ♥ Acer
and leave car running.
Old Mar 8, 2005 | 03:29 AM
blank's Avatar
blank
i rinse the engine off good with a hose after it is cool of course and then spray meguirs tech protectant on it. and leave it rumming for a while 5min or so then it looks just as good as new
Old Mar 8, 2005 | 09:14 PM
Martinrulz's Avatar
Martinrulz
ORIGINAL: mikev08826
Mike should i leave the engine running when i spray on the cleaner or start it up after i spray it down to help evaporate the water? when u say avoid spraying the alternator, you mean with the cleaner or when I'm rinsing it?
Old Mar 8, 2005 | 10:00 PM
dc_mann8's Avatar
dc_mann8
what do you mean only carb's have distrubutors?! pretty sure all cars do..?
Old Mar 8, 2005 | 11:14 PM
98stngfrk's Avatar
98stngfrk
ORIGINAL: dc_mann8
not all cars have distrubuters, non of the modular engines have a distributer.
