Cleaning Engine
That engine doesn't look too bad at all, just a little dusty.
You can use the No Rinse you got and make quick detailer with it, just spray it on and wipe off with a microfiber towel.
Now if the engine was dirtier I would use an all purpose cleaner on the whole engine and then lightly spray off with a hose. Then you can put on your favorite engine dressing.
Happy New Year!
https://mustangforums.com/m_4398337/tm.htm
I put 2 caps of no rinse in bucket of waterand wiped down what I could get to with a microfiber towel.
Looks much better.
Once the weather breaks I'll have to try some simple green or degreaser.
I'll cover the air filter with plastic. What else? Battery?
Looks much better.
How is the process different for cleaning an older engine? More to cover up and protect from water obviously, but would it basically be the same process as in spraying everything with a cleaner/degreaser and letting it sit, then hosing it all off?
[IMG]local://upfiles/43463/E4B1D41185FE46E0A03CDDBCBB925228.jpg[/IMG]
For the people that are talking about using Simple Green on the engine, be very careful with this stuff. It can discolor and damage any polished metal or chrome in the engine bay. Make sure you use an all purpose cleaner with a low acidity level.
