Haze after waxing
Old May 25, 2008 | 05:54 AM
  #21
my06shaker's Avatar
my06shaker
Default RE: Haze after waxing
Spray detailer will take the haze off
Old May 25, 2008 | 08:34 AM
  #22
SVTBill's Avatar
SVTBill
ORIGINAL: Riptide
My car already has a ton of swirl marks etc.. I can't afford the porter cable and I have other priorities at the moment so a polish isn't gonna happen. Right now I just live with the imperfections. Hence why I didn't do anything but wash, clay, and then straight to wax by hand.
As for the duster eventually I'll be getting the PC tool (probably next year) and will do a real thorough job on the finish. If I notice scratches coming in from it after that then I might consider alternatives. The issue is, how else are you supposed to keep a black car from getting dust on it short of washing it on a daily basis? Screw that.
there is no way to, really. you can QD it the next day, but then you're risking your black paint.
one way to prevent fine scratches and swirls is use the 2 bucket method. 1 rinse bucket, and one wash bucket
Old May 25, 2008 | 09:51 AM
  #23
sowaxeman's Avatar
sowaxeman
Retired Moderator
Using a good polish by hand will probably not remove your swirls, but I bet it will take care of the haze. Basically you need to polish until you get the finish you are after (haze free), because applying wax is only going to act as a protectant on top of the finish you create.
I have had good success with Meguires Show Car Glaze (not sure of the exact name or product number off hand), but its is their pro line in the beige bottle that is sold OTC. It is a polish that should help with the hazing, even though it says Glaze in the name.
I'm sure Justin has some good polishes that will also work by hand.
Old May 25, 2008 | 08:44 PM
  #24
DuFFMaNN's Avatar
DuFFMaNN
Too keep your car clean, Spray Wash from Justin, and a microfiber.
It does wonders.
Old May 27, 2008 | 05:44 PM
  #25
Burtonsnow157's Avatar
Burtonsnow157
if you didnt wash the car after you clayed it that can leave some haze from the quick detailer getting left behind. i had haze really bad after i clayed, so i washed and then waxed and its perfect
Mr. D
Sep 17, 2015 08:17 AM
Earl
Apr 10, 2005 09:42 PM
Earl
Apr 5, 2005 02:29 PM
ParrotHead
Sep 1, 2004 09:35 PM
atlantic pony
Sep 17, 2003 12:17 PM
