Quick detailer between washes?
Old Jul 22, 2008 | 12:37 PM
Riptide's Avatar
Riptide
Default Quick detailer between washes?
Is it OK to spray and wipe down my hood and the roof of the car with some quick detailer in between washes as long as I run the california duster over the surfaces first to get most of the dust off?
Old Jul 22, 2008 | 12:43 PM
StriderTacticaL's Avatar
StriderTacticaL
Default RE: Quick detailer between washes?
Sure, just make sure you constantly use a clean side of the towel
Old Jul 22, 2008 | 01:02 PM
Nabster's Avatar
Nabster
That's what I do, no problems here.
Old Jul 22, 2008 | 01:04 PM
Riptide's Avatar
Riptide
How can you tell if you are using to much detailer? I'm wondering if that might be an issue. Sometimes I seem to get a milky white kind of haze showing up in the sunlight after I apply detailer to the car.
How much should one "squirt" from the bottle cover? A 2'x2' section?
Old Jul 22, 2008 | 01:27 PM
Juztang's Avatar
Juztang
It sounds like if you hare getting a haze you are using too much. You really only need to use a fine mist and then wipe it off with a microfiber towel.
Old Jul 22, 2008 | 01:37 PM
Riptide's Avatar
Riptide
It's hard to avoid getting more than a fine haze in the center of where you spray. How far away from the panel should I be holding the sprayer?
Sorry for all the stupid questions.
Old Jul 22, 2008 | 01:39 PM
StriderTacticaL
What kind of quick detailer did you get? I have Meguiars ultimate quick detailer and the spray nozzle shoots the stuff out very fine...
Old Jul 22, 2008 | 02:00 PM
StriderTacticaL
Just spray from far enough to get a decent, fine wide coverage
Old Jul 22, 2008 | 06:16 PM
Nabster's Avatar
Nabster
ORIGINAL: Riptide
If you're doing it in the sun, that may be contributing to it, if it's in the sun the panels will heat up and dry the detailer prematurely causing the hazy streaks.
Old Jul 22, 2008 | 08:45 PM
Juztang's Avatar
Juztang
Speaking of hot panels........another option is to spray the microfiber towel with quick detailer and then wipe the paint when the panels are hot. This works pretty well too.
