Mildew smell, please help.
Old Aug 3, 2008 | 10:10 AM
01GTDropTop's Avatar
01GTDropTop
Default RE: Mildew smell, please help.
Thank you, I'll try that. I have recently put in a....hahaha, a baking soda refrigerator(sp?) pack to "soak" up any moisture. So far that is doing the trick. I am still going to pull the back seat, but my philosophy final and paper is due in a couple days. So I will get to it after.
Thank you,
Phil
Old Aug 25, 2008 | 08:37 PM
ddice01gtvert's Avatar
ddice01gtvert
Default Same problem
I have an '01 Gt vert as well and I have the exact problem. The water is getting in at the bottom corners of the rear window. What type of sealant are you using to fix the problem?
Old Aug 28, 2008 | 01:35 PM
01GTDropTop
Some clear silicone sealant will due the trick. Get a Q-tip with alcohol, clean it, and apply sealant. Make sure you get it there real good, wait a day, and check it with the hose.
Old Aug 30, 2008 | 07:36 AM
ddice01gtvert
Default Thanks
Thanks, I'll try that.
bradleyb
Nov 27, 2015 07:50 PM
Thunderball
15
Nov 22, 2015 11:49 PM
Dathan
Oct 5, 2015 05:52 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
mustangheaven
Sep 29, 2015 11:00 AM
