Cleaning Windshield
Old May 13, 2005 | 10:33 AM
Steven6095's Avatar
Steven6095
Default Cleaning Windshield
Hi My windshield and I are having a problem.
I have a combination of water spots and just good olde road film all over it.
I have tried vinegar without much luck.
Anything out there to really clean a windshield?
Thanks
Steven
Old May 13, 2005 | 12:16 PM
O2GT's Avatar
O2GT
Default RE: Cleaning Windshield
TRY NEWSPAPER AND WINDEX NO JOKE.. Or also try fine steel wool.. you wont scratch the galss dont woory use a lot of windex.. but the newspaper trick is old school it really works
Old May 13, 2005 | 12:24 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
ORIGINAL: Steven6095
Thanks
Steven
Laquer thinner
Old May 13, 2005 | 06:11 PM
Phillyblunt474's Avatar
Phillyblunt474
ORIGINAL: O2GT
I use newspaper and windex for everything its so good, ive ran into a sliding glass door after doing that lol
Old May 13, 2005 | 06:15 PM
Jimmz's Avatar
Jimmz
You can also use invisible glass. It cleans glass like no other, I use it on all my windows including my windshield and it does the trick. The problem with Windex is that it leaves streaks, and can be harmful to your windows if their tinted, so i'd try invisible glass....
Old May 13, 2005 | 07:05 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: Phillyblunt474
ORIGINAL: O2GT
If the Windex and Newspaper don't work, try Simple Green. The only down side is that it leaves a film of its own so you have to follow with a Windex chaser. Cuts right through road grime and bugs though!
Old May 23, 2005 | 01:46 PM
cobrakid's Avatar
cobrakid
Like Phillyblunt said: Use newspaper and windex or window cleaner of your choice. I use the classified, with less pictures on it.
Waterspots are caused from hard water drying fast. Clean the windows in the shade. The reason for using newspaper is it doesn't leave any lint of any kind on the window. I use "rainex" afterwards. Fresh "Rainex" also makes your wipers last longer when your use them.
4cylinderplus2
Oct 9, 2020 07:45 PM
baddog671
Jul 26, 2016 01:20 PM
EZFEED
May 5, 2016 08:54 PM
Dathan
Oct 5, 2015 05:52 AM
folivier
Sep 26, 2015 02:28 PM
