remove super glue
Old Sep 1, 2008 | 08:04 PM
02stangridin's Avatar
02stangridin
Default remove super glue
How do I remove super glue from my car??? It got on the paint when I reattached my window vents. Well I recently took the window vents off and there is still some super glue on the paint. What do I use to get that off? Thanks!
Old Sep 1, 2008 | 09:36 PM
92stangerang's Avatar
92stangerang
ive heard acetone. id try goo gone first with a tooth brush. if neither work then just wet sand that spot with like 1500 or 2000 grit sandpaper and high speed buff with 1500 grit compound.
Old Sep 2, 2008 | 08:44 AM
Dan04COBRA's Avatar
Dan04COBRA
Try a claybar first. I sprayed crazy glue all over my Cobra by accident and a claybar + Poorboys SSR2.5 and a Orange pad was able to completely remove it.
Be careful with wet sanding, you need to use a flexible block otherwise you'll make a nasty mess of your clearcoat.
Old Sep 2, 2008 | 02:40 PM
02stangridin
What is the Poorboys SSR2.5? I tried to just claybar the area with the detailing spray and it did nothing.
Old Sep 2, 2008 | 06:33 PM
khooper's Avatar
khooper
Sorry Dude if its gone hard, it will have bonded with the paint and you will not be able to remove it with out damaging the paint.
__________________
Check out Discount Volvo Parts
Old Sep 2, 2008 | 09:06 PM
02stangridin
__________________
Check out Ford Tailgates
Yeah i think it has, idk what else to do but the claybar wouldnt help at all. I also tried goo gone with no help, paint thinner, rubbing alcohol...idk what else.
Old Sep 4, 2008 | 08:52 AM
Dan04COBRA's Avatar
Dan04COBRA
Not exactly true khooper.
My crazy glue was stuck on for 48 hours, with sun hitting it and I was still able to remove it. It took a lot of elbow grease and time.
02stangridin, do you have any intentions of buying a buffer for your car? A Porter Cable and the right cutting pads & compounds could certainly remove or help the situation.
I claybarred for a ridiculously long time and got it to take whatever it could off the car, then I polished with a PC for a couple hours until it was finally gone.
BOB ROME
Jul 26, 2023 01:54 PM
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
Suree_Mustang_2009
Sep 25, 2015 12:58 PM
