Help-over spray all over
Old Nov 19, 2008 | 08:21 AM
loribelle's Avatar
loribelle
Default Help-over spray all over
I have a serious problem. There is overspray all over my mustang.
THis is an issue at my work place. Some use car covers otherdon't wash
their car so the dust keeps the spray from sticking (so I've heard)
I have a few questions:
What car cover works best and where is the best place to get it?
What can I do to get the over spray off my "beautiful candy apple red" mustang.
Old Nov 19, 2008 | 10:16 AM
buster's Avatar
buster
I had overspray all over my car (long story). Claybar took it off. I think a cover is a cover, depending on what you want to use it for i.e. waterproof, etc.
Old Nov 20, 2008 | 05:07 PM
Lynn Phillips's Avatar
Lynn Phillips
Former Vendor
I agree, and overspray removal is actually very easy with a clay bar, just be sure to use a good protectant when you are finished as most clays will remove the majority of your wax too.
For a clay I would recommend the Clay Magic Perfect Finish Kit, it is a medium as far as aggressiveness and should take care of the overspray for you.
Lynn
Old Nov 21, 2008 | 02:38 AM
robsimp's Avatar
robsimp
make sure you follow directions when you clay... and use alot of lubricant..
Old Nov 22, 2008 | 10:36 AM
BillyL207's Avatar
BillyL207
Obsessive detail also has a nice claybar that I use for my business. 8oz for 23.95. should be able to get alot more use of it opposed to 4oz. 8oz will save you a bit of cash and be able to get more use of it. Just make sure you take a knife and cut the claybar into fourths or eights so if you drop it on the ground you only have to dispose of that tiny piece opposed to throwing the whole thing away. Good luck!
Old Nov 23, 2008 | 10:05 AM
Dan04COBRA's Avatar
Dan04COBRA
Overspray isn't always easy to remove with a claybar....
It depends on how clean the surface of your car was, and if the overspray has been on for a couple days at the least it's probably going to take a fair amount of elbow grease with a claybar before it grabs and takes it off. Sometimes a claybar won't take it off without spending hours on a 2x2 section and it's better to take light polish & a buffer to knock it loose.
Old Nov 26, 2008 | 02:54 PM
crueheadstang87's Avatar
crueheadstang87
wetsand with 1500, then 3000 trizac and then polish and glaze it. be careful no to sand through the paint though. clay bars work ok too
guitarman376
Oct 11, 2015 01:47 AM
pimp2303
Sep 17, 2015 08:45 PM
5.0 kevo
Sep 3, 2015 06:24 PM
mtxplod
Aug 29, 2015 01:43 AM
dochawk
Aug 25, 2015 08:25 AM
