How to remove window tint?
Old Nov 27, 2008 | 12:23 AM
PennState's Avatar
PennState
Default How to remove window tint?
Just got my second window tint ticket tonight. So I think its time to remove the driver and passenger door window tint. What is the easiest and less messiest way of removing it?
Old Nov 27, 2008 | 03:28 AM
illin's Avatar
illin
Take it to a tinter...
Most will charge you $20-30 to pull it off and TRUST me...it is well worth it. The stuff does not just come off.
Here in IL, we are not allowed any side tint. I am running 30 back and min windows and 45 on the sides...looks factory and provides exactly what I wanted. Have never been stopped and my Stang in not shy in color either...
Old Nov 27, 2008 | 08:28 AM
kc99stangv6's Avatar
kc99stangv6
Considering its the side windows, I'd say get some water, a damp cloth, a couple of razor blades and get to work. That's how I got mine off. Try to peel the tint off slowly and carefully. Scrape off the left over residue with the blade while using the damp cloth to remove the lose residue and keeping the glue wet for easier removal...
Or you could just go with what illin said.
Either way, here's a link that should help you out regardless of what you decide to to: http://www.tintdude.com/remove.html
Good luck
Old Nov 27, 2008 | 09:57 AM
illin's Avatar
illin
I tried the above...as I do all my own wrenching...but after addign a $20 in the curse jar...I went out back and let it go!
Then drove 2 miles to a tint shop and was out the door in 30 mins!
Old Nov 27, 2008 | 12:57 PM
PennState's Avatar
PennState
ok so i got both of them...and i removed glue for one window which took 2 hours, so anyone have a way of taking the glue off faster...
Old Nov 27, 2008 | 03:03 PM
HateWhatOwnsYou's Avatar
HateWhatOwnsYou
use goog one or go to auto zone and purchase some tint remover spray. it kinda melts the glue and it can be wipe/scraped off faster....
can anyone give me some insight on removing tint on a rear window with the defroster thinkgs?
im afraid if i take my tint off the rear window i will pull them off with it.....
Old Nov 27, 2008 | 04:36 PM
mike08's Avatar
mike08
it just takes like 20 minutes per window. spay some water or soap and water. let sit for 2 minutes and just use the razor and thats it. you may spray a little here and there just to lube it up. did this last night and got new window tint last night hah
and the back window i recommend a pro or you can use a steamer and go slow. it will remove the glue and tint at the same time and leaver your defrosters
Old Nov 28, 2008 | 02:08 PM
PennState's Avatar
PennState
ok thanks guys, got most of it off today....i miss my tint soo bad....my car feels naked now.
Old Dec 6, 2008 | 07:39 PM
5.0muscle's Avatar
5.0muscle
Talking
i wish i saw this sooner. i found by accident that if you wait for extremely cold weather, it will come off easy without any ammonia, etc. for those in living in the northeast i guess that would be one( and the only) advantage we have over those in the sunbelt.
Old Dec 9, 2008 | 03:58 PM
winner99's Avatar
winner99
I tried taking mine off in the cold weather and it didnt make a damn difference. Jus buy a heat gun and it will come off like it went on. A blade is the last thing you'd want to do.
