How to remove window tint?
Old Dec 9, 2008 | 04:50 PM
05 Mustang's Avatar
05 Mustang
take a razor blade and starting peeling at the upper corners of the windows. once you get the corners loose, you should be able to pull the tint off in one complete piece. once the tint is off, take the razor blade and your choice of removing agents (I've used just plain windex in the past) and start scraping the adhesive off.
just take your time and it'll all come off.
Old Jan 29, 2009 | 09:21 AM
jchambers's Avatar
jchambers
The best way Ive found is wait for a really sunny day, cut a black trash bag in pieces to fit closely to the size of the windows. (you can lay the trash bag on the outside of the window to measure size) Then, spray windex or anything with ammonia in it all over the inside of the window. Carefully place the trashbag against it and work out as many bubbles as you can. Make sure it is covering the entire window and parked in the direct sun. Close all windows and doors and let it "bake" in the sun. After 30 minutes or so you should be ables to pull the tint off with the trash bag very easily along with most of the glue. Any glue left over you can use goo gone with 0000 steel wool. (NEVER use steel wool or razor blades with a dry window) This works especially well on the back window without harming your defrost. Also since you are spraying the rear window liberally, you may want to put some down over the back deck so it isnt dripping all over it while you are trying to cover it witht he trash bag. Hope this helps!
Old Jan 29, 2009 | 10:43 AM
genesis's Avatar
genesis
Former Sponsor
Yea i wait on a sunny day to do this it will make it a lot easier
Old Feb 5, 2009 | 05:01 PM
lcdt94's Avatar
lcdt94
Originally Posted by 5.0muscle
i wish i saw this sooner. i found by accident that if you wait for extremely cold weather, it will come off easy without any ammonia, etc. for those in living in the northeast i guess that would be one( and the only) advantage we have over those in the sunbelt.
You have better IATs, too.
cr620
Oct 3, 2022 10:18 PM
jwog666
Dec 27, 2021 08:09 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Dathan
Oct 5, 2015 05:52 AM
