Condensation In Headlight
Old Dec 1, 2008 | 08:00 PM
SubZero00GT's Avatar
SubZero00GT
Default Condensation In Headlight
If i removed the headlight from the mustang and resealed it with a clear adhesive sealant would it seal the headlight and not allow condensation inside?
Old Dec 2, 2008 | 05:02 AM
562cobra's Avatar
562cobra
first, you will have to lay your headlights down in direct sunlight to allow the condensation to evaporate.
Then, seal where the plastic meets the black housing to prevent anymore con-den-say-shun from getting in.
Old Dec 3, 2008 | 11:44 AM
SubZero00GT
what about using a blow dryer to get out all of the condensation?
Old Dec 3, 2008 | 05:45 PM
562cobra's Avatar
562cobra
The direct sunlight method is what I would try.
there are also other methods like the oven.
but i don't have alot of info on that.
Old Dec 3, 2008 | 07:42 PM
defconfire's Avatar
defconfire
I baked mine in the oven for like 10 min at 150* to get all of the moisture out. just make sure to take the bulb out before you cook it lol.
Old Dec 3, 2008 | 08:44 PM
mike08's Avatar
mike08
^ hah i wonder if people have actually left it in there
Old Dec 3, 2008 | 08:59 PM
562cobra's Avatar
562cobra
i have a thread in here to restore the outer part of the headlight, just in case you need it.
Old Dec 4, 2008 | 02:12 PM
SubZero00GT
Alright so the blow dryer worked great.. Except there were water marks all on the inside now...
Old Dec 4, 2008 | 02:13 PM
SubZero00GT
I put it in the oven for 10 minutes at 250 degrees and peeled the plastics apart. Cleaned the inside real good and now i have RTV Clear Silicone drying on it.
Old Dec 14, 2008 | 03:45 PM
0blivion's Avatar
0blivion
while you were in there did you notice any way to remove the amber portion of the turn signal?
