Condensation In Headlight
If you have moisture in the headlight check for cracks or check the seal on the light bulb. Also check the groove between the cover on the back of the headlight and the clear plastic on the front, sometimes a small bit of silicon around the case and the front will help that problem.
I have a problem with my driver window. I hear the motor running and a click sound like the motor is trying to engage but the window wont go up or down. If i grab the window and pull up the motor sometimes ingage and push the window all the way up. Going down i have to push it by hand with the switch on the down position in order to get the window down. Does any one have any suggestions how to fix this problem???
Seanam
Oct 4, 2015 10:15 AM
2000, 20052009, condensate, condensation, ford, headlight, headlights, moisture, mustang, oven, putting, z06
