Paint gun/Compressor set up
Old Jan 21, 2010 | 03:46 PM
bopiela's Avatar
bopiela
Default Paint gun/Compressor set up
Hey guys. Hoping someone can help me out! I want to get a good paint gun set and a compressor to use for painting parts for cars - I would say I am not going to paint an entire car at once, maybe a door or hood at most (if that changes how big of a compressor I would need).
What should I look for in paint guns?
And how big of a compressor do you think is needed for that type of painting?
Thanks a ton!
Old Jan 22, 2010 | 10:42 PM
bopiela's Avatar
bopiela
Is there maybe a different section I should ask this? Or, anyone?
Old Jan 23, 2010 | 04:04 AM
UBendIMend's Avatar
UBendIMend
If you don't want your compressor running constantly, I would go with at least a 60 gallon tank with a 2-stage compressor.
As far as paint guns go, I believe you get what you pay for. I personally prefer the "Sata" brand guns, but depending on the model gun you buy, they are $400 and up. A good starter quality gun manufacturer is "Devilbiss." They are considerably lower in cost and provide good results.
Old Jan 23, 2010 | 11:47 PM
bopiela's Avatar
bopiela
thanks ubend!! i was hopin i wouldnt need that big of a compressor, but dont wanna go wrong. how big would you need if you were going to paint a whole car at once in a booth? would it be a mammoth one?
Old Jan 24, 2010 | 03:25 AM
UBendIMend's Avatar
UBendIMend
I have sprayed completes with the set-up I explained above. Although you may be starting out just spraying a couple panels, you won't have to worry about your compressor running all the time and you will have room to grow into spraying completes.
Old Jan 24, 2010 | 10:33 AM
bopiela's Avatar
bopiela
oh, ok. awesome to know!! thanks a ton man! greatly appreciated.
Old Jan 24, 2010 | 02:12 PM
UBendIMend's Avatar
UBendIMend
No problem! Any other questions, feel free to ask!
Old Jan 24, 2010 | 06:32 PM
bopiela's Avatar
bopiela
I may have more, especially since I am looking at paint guns, and they have there own terminologies... haha. appreciate it man.
Old Jan 26, 2010 | 01:44 PM
bopiela's Avatar
bopiela
UBend - opinion on the following paint gun sets please....??
1. http://www.ketone.com/proddetail.php?prod=MXA-W989K
2. http://www.ketone.com/proddetail.php...802342&cat=132
Old Jan 27, 2010 | 07:33 PM
UBendIMend's Avatar
UBendIMend
.......Well, I have never used "Maxair" before, but according to the reviews, it seems like a good buy. That kit would be nice to have since it comes with two spray guns and a touch-up gun. That way you could have one for your clear-coat applications and one for your base-coat applications....then you would just have to buy a cheap primer gun if you needed one.
As far as "Devilbiss" goes, I have used these guns before and I know they put out good results.
Now if it was me, I would buy the Maxair kit simply because it comes with two guns, which you will need. You don't want to spray your base through the same gun as your clear, in case you didn't know.
Since you are starting out doing small jobs, I would try the Maxair kit. If it sucks, at least you only spent a little over 100 bucks. If that ends up being the case, then I would buy Devilbiss or Sata, but like I said, they get spendy. I'm kind of curious about that Maxair kit. Let me know what you decide!!
