buffing marks?? helpp
Old Aug 27, 2010 | 06:28 PM
stealth32's Avatar
stealth32
what does cleaner wax do. And i tried what u said it doesnt rub off when i touch it. i have to agree...the 3m stuff i used to detail at a autobody shop and there 3m compound and polish were great. so should i go over with it then with polish if you dont think the cleaner will cut it
Old Aug 27, 2010 | 06:34 PM
08Steeda's Avatar
08Steeda
Swirl Remover first, then Cleaner Wax then some Carnuba.
Old Aug 27, 2010 | 06:39 PM
stealth32's Avatar
stealth32
what is the cleaner wax do!! i just want to do it right if im gonna be working on it for a long time. u sure i dont have to polish it again.
thanks guys
Old Aug 27, 2010 | 07:32 PM
19stang88's Avatar
19stang88
Buffer marks? with a PC? that is odd. The Porter cable is the safest polishing machine there is. Don't believe me? http://youtu.be/2XAqpOe9Zt4 check this out right here. I use Adam's polishes. They are great products, and i love the ease of use while still accomplishing outstanding results. Check them out http://www.adamspolishes.com/t-videos.aspx
Old Aug 27, 2010 | 07:41 PM
08Steeda's Avatar
08Steeda
Sorry - Cleaner wax has a very mild abrasive in it to remove fine scratches and scuffs but not really a rubbing compound. It takes a lot of elbow grease to eliminate deeper scuff marks or scratches with it because it is not as aggressive and won't cause damage as easily.
I usually use it after the Deep System polish.
Step 1 is Clay Bar - By Hand
Step 2 is Cleaner Wax - By hand with applicator pads
Step 3 is Deep Crystal Polish - Porter Cable Microfiber cloth bonnets - medium speed.
Step 4 is Deep Crystal Carnuba Wax (Liquid) or Gold Class Carnuba Paste - Finishing Pad Higher Speed Lighter Pressure
Step 5 is BUFF with a pure Wool Finish Pad
Old Aug 27, 2010 | 07:42 PM
stealth32's Avatar
stealth32
i used mothers power ball BEFORE i got the pc. I got the pc about 2 weeks ago and havent tryed it out yet
08Steeda's Avatar
08Steeda
I think he got them from the Mothers Powerball for Paint. Which is on the end of a drill not a Random Orbit machine like the PC.
Old Aug 27, 2010 | 07:47 PM
stealth32's Avatar
stealth32
i appreciate it 08steeda im gonna try it out tmrw let you guys know. does drying the car also effect the paint when u put on the wax and stuff i heard the squeege towl takes off the wax when u wash it. How do you guys dry your cars
Old Aug 27, 2010 | 07:51 PM
08Steeda's Avatar
08Steeda
Jelly Squeegee and a synthetic sham. But then I don't wash mine with water any more. I keep it in the garage and only really need to dry it when I get rained on.
I use detailer to clean it with CLEAN Microfiber towels.
FYI - Black is probably the toughest color to detail well. It just shows every flaw. But once you get the proper method and process down it will look like it is WET and almost Deep.
Old Aug 28, 2010 | 02:29 AM
19stang88's Avatar
19stang88
That explains the buffer marks. Black has a lot of depth!!
tmdm
May 2, 2021 02:49 PM
baddog671
Jul 26, 2016 01:20 PM
Aug 12, 2015 05:39 PM
