Help!! Detail Guru's Scratch question?
After the thaw the last couple of days I took my stang out to wash, I noticed a long 3 inch hairline white scratch on the hood thought it was dirt at first but it wasnt. Other than the paint pin any easy suggestions for newby at making a scratch less noticable or removal?
YES! it is called a polish. NOT by hand, since it will be nearly impossible to remove the scratch. Also, run your finger nail across the scratch, if it gets caught, you may need wet sanding. A picture would be optimal to determine necessary actions. Dylan@adams is a top notch vendor here at MF. If he reads this, he can give you more information. For now, check out these videos from Adam's polishes on how to go about your problem.
http://www.adamspolishes.com/t-Videos_DVD5_8.aspx
Let me know if you have anymore questions
JoshyGT
Sep 19, 2017 08:52 PM
Sep 17, 2015 07:57 PM
