Detailer on Windows
Old Jul 28, 2013 | 11:20 AM
72MachOne99GT's Avatar
72MachOne99GT
2010 Blue Ball Award Recipient
Default Detailer on Windows
I was giving my car a quick once over the other night and must have swapped towels by accident because my windshield, rear window, and passenger side window are smeared as fvck.
like someone took a clear poop then smudged it EVERYWHERE on those windows.
tried using invisiglass and some other window cleaner to absolutely no avail.
other than clay barring my windows, is there anything that does a good job of clearning up windows?
Old Jul 28, 2013 | 02:34 PM
wcgman's Avatar
wcgman
What about a degreaser followed by glass cleaner?
Old Jul 29, 2013 | 10:18 AM
72MachOne99GT
A spray on degreaser of some sort, I dont know.
I imagine it would work but is degreaser generally glass and potentially paint friendly?
Old Jul 29, 2013 | 11:01 AM
wcgman's Avatar
wcgman
I would avoid using it on paint...but then my father in law likes to use old school ether on everything. If ether isnt available, he breaks out the gas can.
Old Jul 29, 2013 | 08:24 PM
SON1C's Avatar
SON1C
try a glass cleaner like megs d120 or eco touch window clear
if not try one of the waterspot removers by chemical guys -- they have two either should work
otherwise try a quality apc like meg's apc+ or cg's allclean+
if somehow none of this work, try a degreaser ex. megs degreaser , cg grime reaper etc
if these don't work simply use an abrasive like cg v32 or m205
your glass is very tough and abused, you can only improve it
once your issue is resolved coat it with a quality wax or sealant to protect it and aid in keeping it clean and sheeting water off while driving.
Old Jul 31, 2013 | 11:07 AM
72MachOne99GT
Ended up using dawn in warm water with a wrung out dish cloth to remove the grease/detailer then hit it again with my cleaner.
much better but not perfect.
Old Aug 8, 2013 | 08:12 PM
Whitedarkness23's Avatar
Whitedarkness23
steel wool might do the trick
Old Aug 8, 2013 | 08:20 PM
72MachOne99GT
I use that on my ***** retard.
Old Aug 9, 2013 | 09:15 PM
wcgman's Avatar
wcgman
As long as you avoid the shaft, no problems there. Otherwise the chafing might get to ya.
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
KingRando
Oct 2, 2015 08:06 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
