SCG Pro - Machine Finish™ Polish
Old Sep 4, 2014 | 09:27 AM
Surf City Garage's Avatar
Surf City Garage
Former Sponsor
Default SCG Pro - Machine Finish™ Polish
SCG PROFESSIONAL MACHINE CUT™ POLISH
Remove swirls, scratches, and 1500 to 2000 grit sanding marks with SCG Pro Machine Cut Polish. The custom hybrid-abrasive blend utilizes two distinct types of cutting agents to provide powerful swirl and scratch removal, but still finishes down so clean, often eliminating the need for a second step! Absolutely no silicone means, Machine Cut™ Polish is body shop safe and effective with dual-action, orbital, and rotary polishers with foam and microfiber pads.
Discover what perfection can look like with the amazing paint correcting power of SCG Professional Machine Cut Polish!
Directions:
NOTE: Always begin with a clean and dry surface.
  1. Prime pad by applying approximately 10-12 pea sized drops of Machine Cut™ Polish evenly over the face of a moderate to aggressive polishing pad.
  2. With machine at low speed, spread product over section to be polished.
  3. Increase machine speed and work the polish until it appears thin and oily
  4. For additional panels use only 2-4 additional drops of polish.
To prevent product buildup, clean or replace pad as needed.
lovesilver
Members Mustangs
May 9, 2019 09:18 PM
baddog671
Jul 26, 2016 01:20 PM
jerrytubes
Oct 23, 2015 12:11 PM
flash_xx
Oct 16, 2015 07:23 AM
folivier
Sep 26, 2015 02:28 PM
