What are cams?
Old Apr 24, 2003 | 12:04 AM
Slteath's Avatar
Slteath
Default What are cams?
im trying to learn as much as i can about these engines so if someone can explain cams to me itd be much appreciated
Old Apr 24, 2003 | 02:00 AM
jeep45238's Avatar
jeep45238
I ♥ Acer
Cams are basically sticks inside of the engine (or on top, depending on set up) that moves the valves in and out.
By getting cams, you change when the open and close, and by how much.
Old Apr 24, 2003 | 05:12 PM
Slteath's Avatar
Slteath
thanx for the info. how do people improve their cams? and is that a good mod for a 00gt?
Old Apr 25, 2003 | 08:11 PM
stanglover's Avatar
stanglover
lt depends on how you'll use the Mustang. People improve their cams by getting a higher duration/lift cam. lf your car is for the street, don't go higher than 260-265 degrees of duration.
Old Apr 27, 2003 | 03:14 AM
jeep45238's Avatar
jeep45238
I ♥ Acer
Translation (since you probably have no clue what he's saying):
Look for street or street/strip cams.
http://auto.howstuffworks.com/engine-cam.htm
That is a SOHC (single overhead cam) set up.
http://auto.howstuffworks.com/camshaft.htm
This'll help you see what he's talking about in more detail.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
