brakes locking up
Old Sep 4, 2006 | 02:24 PM
robert912004's Avatar
robert912004
Default brakes locking up
I have a 65 with a 302 and i drove it around the block yesterday and i found out that the driver side drum was locking up. Is this common or is there something wrong?
Old Sep 4, 2006 | 02:34 PM
Gun Jam's Avatar
Gun Jam
Default RE: brakes locking up
locking up when braking or when just driving around with no brakes applied?
when brakes are applied the idea is to have equal braking force to both front wheels and both rear wheels (both fronts should lock at same time) (both rears should lock at same time) if not the car will pull to one side when brakes are applied.
Note temperatures for FR FL should be the same as well, temps for RR RL should also be equal
Gun
Old Sep 4, 2006 | 06:07 PM
MidNite27's Avatar
MidNite27
My right rear tire locks up under heavy braking due to a leaky wheel cylinder.
Old Sep 4, 2006 | 09:23 PM
robert912004
it locks up when applying the brakes and pulls to the driver side.
Old Sep 5, 2006 | 10:27 AM
DGA's Avatar
DGA
In the time it took for you to come here and write up your problem you could have pulled the wheel and had a look.
Sorry to be harsh but sometimes that's the easiest and best first step.
Old Sep 5, 2006 | 02:41 PM
Gun Jam's Avatar
Gun Jam
Yeah but now I get to tell him to check his passenger side first and see if there is brake fluid around the cylinder, to check the pads and drum, and with the drum on have someone apply the brakes and see if you can still turn the drum to see if its even working at all.
Then check driver's side too and look for the same things and do the same tests.
Gun
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
Sep 25, 2015 06:58 PM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
