which wire goes to the choke?
Old Sep 5, 2006 | 10:15 PM
green_blurr's Avatar
green_blurr
Default which wire goes to the choke?
Which wire goes to the choke from the firewall to engine gauge harness?
[IMG]local://upfiles/43944/6965FF547E4B45B78AA5FF58F85B5A41.jpg[/IMG]
Old Sep 5, 2006 | 10:17 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: which wire goes to the choke?
I don't have an electric choke, so let's start from the beginning. What engine, what carburetor, and what year?
Old Sep 5, 2006 | 10:27 PM
green_blurr
its a holly carb 600 and its sitting on a fresh 302 originally it had one wire hooked up from the firewall to engine gauge harness it looked like it was some a## holes idea of wiring it im not sure but where does the wire that hooks up to the choke come from ? can i substitute?
Old Sep 5, 2006 | 10:29 PM
green_blurr
its a 65 ford with no dummy lights
Old Sep 5, 2006 | 11:29 PM
green_blurr
If THERE IS NO JUICE GOING TO THE ELECTRIC CARB DOES IT MAKE A WHINNING SOUND WHEN YOU SHUT THE ENGINE OFF?
Old Sep 6, 2006 | 02:36 AM
Scott H.'s Avatar
Scott H.
Nope,
Pull the PCV valve out of the gromet and see if the "Whining" goes away. If it does, either the breather cap is blocked or you don't have a proper breather cap.
Early vintage Mustangs were not equiped with an electric choke. There is no proper provision provided (the three "P"s) in the wiring harness for an electric choke.
Here are just a couple of the many reliable choices you have.
1). install a manual choke kit (Holley has these kits available)
2). wire in a small 10A relay through the ignition circuit to power the choke.
Here are the top two "Idiots Choice Award" for "Ignorance unbecoming a classic car owner".
1). Wired the electric choke through an accessory lead.
2). Wired the electric choke off the B+ post of the coil.
Presenting these awards tonight; Vin Diesel and Mel Gibson.
jwog666
Dec 27, 2021 08:09 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
lmurf60
Sep 24, 2015 10:07 PM
