air fuel screw settings
what is the shipped settings on both of the air fuel screws for edelbrock carbs (1405) to be exact
mine came different
left was 2 1/2 out right was 2 out
i just want an even place to start
thanks
mine came different
thanks
I have always started at 1 1/2 out from bottom. This seems to work best for me. and then adjust from there, I don't think there is a factory setting , except maybe , at least 2 turns off the bottom.
Nice looking carb.
Nice looking carb.
cool thanks
intake swap went great
thanks to everyone that helped
and mustangsteve.com made it incredibly easy
old out
new in
carb on
the edelbrock ford throttle adapter smacked right into the brace for my ac pump so i took the stock metal rod
got out a die and threaded the end and bolted it to the edlebrock linkage
works great
good thing my kickdown is attached to the pedal
car started right up
floats are set a little high
its surging and i can see fuel dripping from the venturis while it is idling but that should be an easy fix
old out
new in
carb on
works great
Baxsom, do we bother on asking what's on that video?[8D]
Get a vacuum gauge and connect it to manifold vacuum. As long as both screws are set the same: 1.5 turns, or 2 turns, your fine. Start the motor, insure its warm, and watch the vacuum gauge as you adj each screw individually. Adj each screw, noting the turns in or out, until you have max vacuum, and don't over turn the screw, stop at max vacuum. Both screws setting should be very close the the same when done.
Works every time. I'm guessing but stock vacuum should be 16 to 20 psi, give or take.
Sep 1, 2015 08:16 PM
