65 rear end
Like he just said, look and see if the rear end has a removable cover on the back or not. If it does it is probably a late model 8.8. If it doesn't it is most likely an 8 inch, but could also be a 9 inch.
If you have a tach, What RPM are you turning on the highway in 5th doing about 70?
I would recommend 3.50-3.70 gears.
If the diff is a removable piece, with studs and nuts around the front, it's a 8" or 9". You can use a socket and 6" extension on the nut of the 8", but the 2 lower-right nuts on the 9" would be blocked by the pinion housing.
The 8" will be fine, if you are not racing the car. The 8&9 were identical in design, the 9" was just 1" larger and beefier. Currie has a 4-pinion Traction-Loc diff if you need to convert to limited slip, this is stronger than a lot of stock 9" diffs.
fastbackford351
Sep 12, 2015 09:42 AM
Dragonus18
Sep 9, 2015 01:21 AM
