Forum Issues and Feedback Discuss any issues you are having with using Mustang Forums here.
Automatic Censoring?
Old 08-10-2018, 01:40 PM
Urambo Tauro
Urambo Tauro's Avatar
Default Automatic Censoring?
So, is there a list somewhere of all the words that the forum automatically censors?
In a recent discussion about repairing a fuel leak, I typed up a reply, only to find asterisks automatically applied to replace the word "b a r b e d" (minus the spaces) after posting. Is this a glitch? Or is ****** a slang term now? Man, y'all need Jesus haha. I don't know what you were thinking of, but I was talking about fuel fittings.
Well, at least it still lets me type "barb fitting". That works.
Urambo Tauro is offline
Old 08-10-2018, 02:23 PM
99GTvert
is my username.
99GTvert's Avatar
I'm not sure why but ****** was censored long ago, like over 5 years back.
There is not a list of all censored words on the forum.
99GTvert is offline
Old 08-10-2018, 03:20 PM
08'MustangDude
Banned
08'MustangDude's Avatar
Yeah, have no idea why that is a censored word... Maybe someone here
doesn't like those type of fittings...
08'MustangDude is offline
Old 08-10-2018, 03:27 PM
08'MustangDude
Banned
Testing George Carlin's words you can't say on TV.
****, ****, ****, ****, **********, mother****er, ****, farts, turd, and ****.
Looks like the censor needs updated...
Old 08-10-2018, 05:04 PM
Urambo Tauro
Let's see how many of these the censor will let us get away with...
Barb ****** (edit: that was b a r b e d) nipple hose hoses tube tubes tubing clamp clamps clamped clamping clip clips clipped clipping crimp crimps crimped crimping line lines hardline hardlines pipe pipes piping thread threads threaded threading tap taps tapped tapping die dies file threadfile screw turn twist push slide sharkbite shark bite easy quick quik kwik connect connects spring garter garterspring lock lok springlock springlok o ring oring o-ring rubber EPDM nitrile teflon copper aluminum aluminium dowty washer seal sealed sealing seat seated seating banjo flange port AN NPT SAE MM ID OD straight taper tapered flare flares flared flaring flarenut swage swaged swaging swagelok swagelock compression ferrule sleeve male female union couple coupled coupler coupling weld welder welding silver solder soldered soldering braze brazed brazing
Old 08-10-2018, 05:09 PM
99GTvert
is my username.
99GTvert's Avatar
camshafts.
long tube. headers. longtube.
supercharger.
99GTvert is offline
Old 08-10-2018, 08:57 PM
99GTvert
is my username.
99GTvert's Avatar
STRIPPED BOLT HEAD.
CLOGGED INJECTOR.
CONTAMINATED FUEL.
GM SUCKS LOL
99GTvert is offline
