Forum Issues and Feedback Discuss any issues you are having with using Mustang Forums here.
Bad water pump
Old 04-29-2024, 09:18 AM
sfmchief
sfmchief's Avatar
Default Bad water pump
I have a 65 coupe with a 200 ci 3.3 liter 6 cylinder and I知 trying to determine if my water pump is bad the car is getting extremely hot (overheating) and I知 not sure why. I have a 160 degree thermostat in it and it works and I have antifreeze in every hose to include the heater core hose but it痴 still overheating. Any suggestions or input.
sfmchief is offline
Old 04-29-2024, 09:54 AM
proeagles
proeagles's Avatar
If the upper and lower radiator hoses are getting hot, the water is circulating somewhat indicating the thermostat is working and the pump to some degree. Perhaps the radiator is clogged up and not allowing enough circulation to cool the water. Usually when the pumps go bad you will see water seeping out of a hole in the bottom of the pump
proeagles is offline
Old 04-29-2024, 10:10 AM
sfmchief
sfmchief's Avatar
Thanks I will see if water is seeping out of the house hole
sfmchief is offline
Msfoxbody
08-02-2020 12:27 AM
Quick Reply: Bad water pump
