need help setting timing...where is the plug to pull??
Old Mar 1, 2006 | 12:58 PM
ikeybmg's Avatar
ikeybmg
Default need help setting timing...where is the plug to pull??
can you all help me with setting the timing on my 95 gt? and i need to know where the plug is i need to pull first. a step by step for this would be great!!!....thankx
Old Mar 1, 2006 | 01:01 PM
Tim37's Avatar
Tim37
Default RE: need help setting timing...where is the plug to pull??
first off you need a timing light.
you hook it up to the #1 spark plug wire and make sure you can read your timing marks on the balancer then you turn the distributor to what ever the desired time is.
Old Mar 1, 2006 | 01:04 PM
ikeybmg's Avatar
ikeybmg
do you know which plug on the firewall you have to unplug and where its located? where would be a good place to set it with a 347 stroker?
Old Mar 1, 2006 | 01:06 PM
Tim37's Avatar
Tim37
you should be able to set it off the distributor. and it all depends on the cam but about 15 degrees base is usualy a good place to start.
Old Mar 1, 2006 | 01:17 PM
ikeybmg's Avatar
ikeybmg
do any of you know about a plug you have to pull to bypass the eec to set the timing?
Old Mar 1, 2006 | 01:29 PM
waxyourboard's Avatar
waxyourboard
http://www.muscularmustangs.com/timing.php
Old Mar 1, 2006 | 01:30 PM
ikeybmg's Avatar
ikeybmg
dude that has got to be the perfect response...lol, thankx
Old Mar 1, 2006 | 01:39 PM
ikeybmg's Avatar
ikeybmg
where would you set it dude...pretty close to anyways, its 347 with e-cam
Old Mar 1, 2006 | 02:07 PM
turbostang21's Avatar
turbostang21
what octane gas are you planning to use?
Old Mar 1, 2006 | 02:13 PM
ikeybmg's Avatar
ikeybmg
ill use 93.
