i need some help plz guys
Old Mar 2, 2006 | 07:58 PM
jonnymustang's Avatar
jonnymustang
Default i need some help plz guys
ok this is my problem i have a 1983 mustang it has a 3.8 V6 (carb) with an automatic tranny.......i want to put a 5L V8(carb) i want to kno if its posable...will it mount up correctly? and can i use the same tranny? plz help me out guys i need the 5.0 power lol
Thanks
Old Mar 2, 2006 | 08:08 PM
GreyStang's Avatar
GreyStang
Default RE: i need some help plz guys
Well in short, yeah a V8 will fit because Ford offered V8's in that year. You will have to adjust a lot of other things, like cooling system, springs, and yes transmission, but it will all work.
The cheapest way to go is to get an engine/trans from a wrecking yard.
Old Mar 2, 2006 | 08:09 PM
hot wheels's Avatar
hot wheels
wouldn't it be easier and cheaper just to buy an eighties mustang gt?
Old Mar 2, 2006 | 08:44 PM
ikeybmg's Avatar
ikeybmg
well, you can find stock motors cheap in yards. the local junkyard here has like 15 5.0 ho of various ages. with trannys. youll prolly end up rearend swapping sooner than youd like too. bu it can be done and itll all fit. just takes time. and$$
Old Mar 2, 2006 | 08:46 PM
ikeybmg's Avatar
ikeybmg
but yea, if yur wanting to do it easy you can prolly find an 83 gt cheap.
Old Mar 3, 2006 | 07:51 PM
jonnymustang
is it worth doing?
Old Mar 3, 2006 | 08:10 PM
03YellowPony's Avatar
03YellowPony
It would be easier and cheaper to sell the 6er and buy the V8. But yes, it can be done.
Old Mar 3, 2006 | 08:16 PM
randy78045's Avatar
randy78045
I should know this but isnt an '83 a fox? If so, you can do a lot... see signature...
Old Mar 3, 2006 | 09:52 PM
Twister's Avatar
Twister
it can be done, the best site for four eyes (1979-86) is www.foureyedpride.com
Another option is what I have thought about doing to a 4 eye vert (all verts either had the 3.8/auto or the 5.0) is to find a wrecked 99-04 V8 and put everything drivetrain wise (including the EFI)
Old Mar 4, 2006 | 01:49 AM
tinman's Avatar
tinman
Use a C-4 and an 8.8 rearend........
It can be done and has been done but why not just sell it and get a mid 80's GT?
